2TimingTom
- October 12, 2010
- Location
- Littleton, CO
- Littleton, Colorado
- '97 XLT
One of the benefits of doing a SOA is to clear up the underside of the axle- only the diff hangs down, no more spring perches/shock mounts getting banged off of rocks.
This interests me.
But I can't afford anymore lift. I want to keep my truck able to park in my garage. I haven't measured, but the factory roof cross bars are pretty close.
I have a 2" body lift that I could remove to help me with my problem BUT I have sliders and a front bumper custom built to the body with that lift. So I'm sorta screwed there.
I do have the Warrior shackles that I could ditch- although I'd need custom shackles fabbed since the factory shackles didn't survive that removal.
What would it take to do a SOA without getting any lift from it?
The lift gained from the warrior shackles is 1.5-2.0"- how much lift does a SOA net? It's the diameter of the axle tube, right?
So if I did a SOA and a custom length shackle (an inch shorter than factory?) I should be good- right?
.................Or just look into making some spring perch/shock mount skid plates similar to what Brian1 has.
This interests me.
