cj86012
- October 24, 2024
- La Crosse, Wisconsin
- 2017 Ford Explorer Police
Hello all. This is my first post, and looking forward to joining the community. Unfortunately, I'm starting out with problem and any advice is appreciated. I bought a 2017 interceptor that was advertised as with a new 3.5 liter twin turbo motor. Actually, it's 3 years old an 1 month old and just out of warranty. Still, only about 35k on it. I'm assuming timing is OK.
The car idles fine. With light throttle the odo surges. Under load (getting onto freeway onramp) CEL flashes, car loses power and I get several bank 1 misfire codes.
P0300-Random Misfire
P0301-Cylinder 1 Misfire
P0302-Cylinder 2 Misfire
P0303-Cylinder 3 Misfire
No hissing in the engine bay. The MAF is squeeky clean upon inspection.
I plugged in my cheap scan tool and found one peculiar thing.
No live data for
O2 Sensor Bank 1 Sensor 1
O2 Sensor Bank 2 Sensor 1
Further reading has indicated this may be a limitation with my cheap tool failing to read a heated sensor. Screen shot attached.
I'm hoping it's a small thing like a oxygen sensor? High pressure fuel pump? clogged valve or vacuum leak, but with no other codes I'm not sure where to start. The cats are getting hot (1000 degrees) just driving around the block a few times. I got an intermittent P0420 Bank 1 Cat below threshold, but believe this is the result of the misfires and not a blocked cat. Who knows.
Any ideas?
No live data for
Any ideas?
