SOLVED | Page 2 | Ford Explorer Forums
SOLVED
  • Thread starter Thread starter Deleted member 352605
  • Start date Start date
Hey! Wondering how long y'all go between spark plug and wire changes... i go about 30-40 maybe 50k on a set of platinum plugs... i'm still running OE wires, as they have no issues... should i replace them? also same with the alternator it's oe as well, should i put a new one in when i have it out? thanks!
i'm putting more cash into this fix then i 1st expected lol
Platinum plugs are good for 100,000 mile / 2yr. OEM wires, my personal experience was like 10 - 11 yrs. With no problems
If it’s on factory wires then it probably needs a fair amount of other general maintenance like brake fluid swap, coolant flush, transfer case and axle fluid changes.
i did the brake fluid flush about 50k ago, coolant flush 20 ago, rebuilt the diffs a year ago... and other than that, we did oil every 2.5k, coolant every 30-40k, plugs every 50 ish... but i'm still running oe wires...
i'll write down all the history and upload it... it doesn't really include oil changes but the rest should be there...
Going for 30 years or 200k miles, whichever comes first ('96 xlt 2.3l). Might change pcv valve then too. Still gets same mileage as when driven away from dealer with 4 mi showing. It uses no oil between changes (I buy cheapest API-rated can find, less than $1/quart). Never lubricated caliper slide rails either. (Except on install of new rotors and pads at ~140k mi.) DID put in a new fuel filter though; but mighta been unnecessary.
Or maybe I won't ever change anything, long as it keeps running like when new.
Nice!
Also, is this the right part number for the upper intake manifold gasket (in the top under the SOHC engine cover?)
YL2Z-9E436-AA
Nice!
YL2Z-9E436-AA
Corona isolation provided time to find this thread with lots of references. Can't certify, but good time for garage work.
service history EXCLUDING oil every 2500
19500-plugs
26300-radiator flush/diff fluid/transfer case fluid/trans fluid
32300-plugs
34200-alignment
41200-rotate tires/alignment/fuel filter
42300-trans fluid/transfer case fluid/diff fluid/wiper blade
45300- gibson exhaust
47000-battery
47500-drive belt
49200-water pump
51500- Dynomax muffler
55000-trans fluid/plugs/coolant/transfer case
58051-air shocks
60500-upper and lower radiator hose/thermostat/coolant/hood springs/rotate tires/alignment
65000-resonator removal
67500-fuel filter
73500-brake pads
83600-wiper blades, coolant, hood springs
85000-plugs/trans fluid/brake fluid flush/transfer case fluid/diff fluid
91239-speed control sensor/intake manifold
116000-rotate tire, rear pads, front shocks
121700-fuel filter/coolant
122200-serpentine belt
140000-battery
150000-plugs/diff fluid/trans fluid/transfer case fluid
152877-tires/alignment/coolant/front diff rebuild
176000-fuel filter
177000-drive belt/lift gate bracket
181000-plugs, front back pads, trans fluid, transfer case fluid
185000-brake switch
191000-battery
200000-coolant/fog light bulbs
205000-tires/alignment
222000-fuel pump/plugs/transfer case fluid/trans fluid
233923-clean throttle body/maf sensor
234900- front rear pads
242000-thermostat housing/clean throttle body
246000-fan clutch/headlights
247000-battery
252700-rotate tires
253000-speed sensor
261000-coolant
265000-tires
268000-clean iac/fuel filter
273000-water pump/radiator
284000-front rear pads
284000-clean maf sensor
294000-plugs/rear end rebuild/transfer case fluid
299000-upper lower ball joints
301000-sway bar end links
312000-oil pressure sensor
324000-coolant
33000- tires
Very nice service record. I should do that! Some of those are too often and others are not often enough.
Attached is the factory service maintenance interval manual. Personally, I agree with some of it.
Specifically:
Plugs @ every 100K
Fuel filter @ every 30K
Oil change & filter @ every 5K
Most of the rest is perhaps about right. Ford does want to sell you a new truck someday after all.
A few that I don't agree with -
Plug wires are not mentioned in the factory service interval. I'd say 100-150K if not throwing codes or otherwise noticeable.
Transmission fluid is also supposed to be "good for life" (good til death) in normal service. Don't believe that either. I go with 100K is about right.
Factory says rotate tires every 25k, most tire manufacturers require rotation every 5K for warranty.
YMMV.
I wouldn’t wait until 100k for the transmission. Especially on these.
I see no reason to change the fuel filter at 30k. Unless you have a rusty tank they should last WAY longer.
lol... theres probably some other maintainence i didn't write down... but that should be most of it excluding the 2.5k oil changes...
are there any changes i should make to the maintenance as I am probably keeping it for one or two more years...
I swapped my wires with the plugs at 100K because they were over 15 years old, and I was getting a misfire for the first ~30 seconds when started cold in cold/rainy weather. In retrospect my battery was probably getting a bit weak too, combined with driving it less and shorter trips so it wasn't getting fully charged but the plugs & wires swap did the trick and the battery lasted through another winter (barely).
"Sometimes" when you disturb wires that old, they get breaks in them, but even if they didn't, for their low price I'd just as soon reduce the chances of any problems due to old wires. I used ACDelco Pro 16-826K for my 4L SOHC, $26 delivered on Amazon..
Motorcraft wires and plugs, won't use anything else. Change them every 100K miles. No problems yet.
@RickOTR if im planning on keeping it for another 1-2 years or maybe more depending on how much insurance costs, should i still put some new plugs and wires in it, guessing i should tho
Don't know on what that 5K tire rotation is based, and unlike too frequent oil changes, tire stores usually do it for free, under warranty. Nevertheless, I would rather risk paying for a new tire than letting their "torque limiting" impact wrenches abuse the studs and brake rotors that often. Probably not the case for the 2nd gen Explorer, but my daughter bought the tires for her ancient AWD Honda CRV at a well-known place. When working on the brakes, I found out that one stud had the threads completely stripped away, apparently because they started a lug nut wrong, and then forced it. On that vehicle you need to disassemble the wheel hub to replace a stud. The cost of doing that in a garage far exceeds the cost of a new tire.
@1998Exp
wow... scary... also, quick question, for the sohc, do i have to remove harmonic balancer just to do the guides and tensioner on the primary chain? not doing the actual chains, just the guides and tensioners... also, do i have to remove the ac hoses, thanks!
@1998Exp
Sorry, not familiar with that engine. But many members are; for sure someone will respond shortly.
I
I would leave them alone if you plan on selling it in another year or so. If not, go ahead and change them.
@1998Exp
Yep gotta. Remove it to pull the cover
