spare tire replacement | Ford Explorer Forums
eddie baller
chicago hts,il
2004 xls,1997 xlt
i have a 92 xplorer and it didnt come with a spare i was going to go to the junk yard and get a spare. i was wondering if i get a full size wheel will it fit under the truck
Only full size spares can be used on our trucks. The size you need is the same size as the tires already on the truck, which should be 225/75/15, I think. You can check on the door label for the exact size. And yes, it will fit under the truck.
Most Gen 1 Explorers came with 235-75R15's, which is a very common size and readily available...
i was going to use a wheel off a xplorer not the spare wheel but the rim . it would be nice to have a matching spare thanks for the info
Mine didn't come with a spare either, but that's cause the winch that holds it under the truck was rusted out and broken off, so I went to the scrap yard and got a 15" rim and an old tire and just put it in the back. May get one of those swing doors that holds a spare on the back some day when I want my trunk space back.
Size on my 92 is also 225/75/15
u need a rim? i got a few of em! great condition, what one u needing?
That cable can be replaced, I saw a thread here describing how easy it is and from what I saw under my truck it's pretty simple. Only problem is finding one from another truck that isn't already rusted to all hell!
how far r u from chicago. u have any pics of the rims.
thats the rim, and i live in indiana, im about 6 hours from chicago
the spare tire winch is easy to replace. two 13mm (IIRC) bolts, takes 5min.
a 255/70/16 will fit under there, although it's a tight squeeze.
thanks for the help and info. i went to the junk yard today and got a spare off a 96 explorer the tire looks brand new the tire still has the red green and yellow lines on it. sitting next to that was a another explorer on its side and easy acces to the spare tire winch i think i was at the yard for 20 min and it all costed me $35.00
good deal man! u know any one with a ranger/explorer that neds a new rim???
