------------------------------aldive said:I recommend Motorcraft double platinum plugs.
marragtop said:Make sure you do the wires as well. Use anti-seize when installing the new plugs. Also, passenger side plugs are easiest through the wheel well.
MarksSC94 said:Motocraft, Autolites and Bosch (non +2 or +4) are pretty good plugs for stock ignitions. I wouldn't recommend the Bosch Platinum +2 or +4 plugs unless you have an aftermarket ignition from MSD. Though they are excellent plugs, the stock ignition is too week for them to be useful and can cause your engine to miss. Make sure you get some good wires also and make sure all your coil contacts are clean.
:exp:
