nashka
- January 9, 2011
- Panama City, Panama
- 92 eddie bauer
i pulled out the vss on my 93 ford explorer, it was connected to the speedometer cable....the yellow plastic gear at the tip of the vss has damaged gears.... what is the speedometer cable for??? when i search for a replacement vss there doesn;t seem to be any with the yellow gear part at the end of the sensor where it goes into the transfer case? if it is electrically controlled then what is the cable for??
