LukerDooker
- March 25, 2013
- sorry nope
- 2013Limited 301A TuxBlack
...what is it made of? i have been wondering the entire time.
I would guess it is some kind of vinyl made to look like leather....what is it made of? i have been wondering the entire time.
Pleather
...I'm going to make an appointment; I sure hope they take care of it...
Let me know what the diagnosis from the dealership is, JohnC12. If you need any assistance from me, just send a PM my way.
Crystal
Well, since Ford won't fix the two issues I have(leather tear and wheel damage), I guess I have to throw a patch on the rear armrest to make sure the tear doesn't get worse.
Any ideas where to get one?
And in the spring I need to find some new wheels for it.
I don't think it's even pleather... It's not even real stitching.
It's just a molded plastic / rubber formulation.
That picture isn't torn material, it's plastic split open. Some type of glue is your only chance at repair. It can't be "re-stitched" because it isn't stitched in the first place.
This definitely is not a common problem, at least not by the number of posts on this Forum. I think you should speak with your dealer about this problem. Perhaps they can cover a portion of it.I have a split that looks identical, just on a black door panel. I took it to an upholstery shop and they said it is heat molded and the only option is to have the panel replaced. I have 37k, so am I going to have to eat this? Or is Ford stepping up for it because it is so common?
I would suggest that you also contact Crystal, the Ford rep, and see if there is anything she can do for you by contacting your regional customer service manager.
You really have nothing to lose since the entire cost would be on you now anyway.
Good luck.
Go back up to post #13. Click on FordService in the left margin and from the drop down list select, "Send a private message to....." I believe Ashley is on the evening shift and Crystal on day shift. They will require your full name, phone number, mileage, VIN, and dealer info.How do I get in touch with Crystal?
Good luck.
Good luck.
For those with splitting arm rests, what kind of environment are you in?
I'm not looking to "excuse" anything based on environment, just wondering if there's a link.
Like hot environment without tinted windows. Or leaving sun roof open all the time.
Anything along those lines...
Just curious.
