Split Wire under passenger, what are they? | Ford Explorer Forums
Haziness8
West Hollywood, CA
'98 XLT 2WD
found a split wire under passenger side fender here are some pics
it connects back into this thing-a-mobob.
Looks like your cruise control... does yours work?
ill try, any other possibilities?
that is your vacuum canister.
With the vacuum line open to the atmosphere like that yo uare losing manifold vacuum UNLESS there is a check valve up stream
With the engine running does one side of that line suck air?
You need to replace the broken section of hose.
It is plastic vacuum line, auto parts stores typically do not carry the OEM style hose, so you can get creative and make a new section with rubber vacuum line.
