Sport97's sport | Page 16 | Ford Explorer - Ford Ranger Forums - Serious Explorations
Sport97's sport
Post updated:
My name is Vince, I live south of Pittsburgh, Pa. I bought my explorer after i graduated high school(july 08) with 50k for 3500
The Ex:
97 explorer sport, SOHC/auto, leather, moon roof, + mods...
The x: It had 50k miles on it when i got it, and had only minimal rust. Since then the rust has been fixed, and I'm over 100k. Maintenance has been typical with plugs/wires, fuel filter, all 4 ball joints and a thermostat. Running Mobil 1 syn has seemed to quiet the timing chain rattle. Its totally quiet in the summer, and slightly louder in the cold weather.
CURRENT STATE: 12/2011 @101k
-front skid plate
-removed front valance
-relocated front fog lights
-clear corners
-safari bar/lights (victim of rust and off roading)
-bed liner on a few things
-8" sub w/ amp
-4 pioneer speakers
-air box mod
-new rockers w/o rust:)
-cobra CB w/ 2 3ft wilson whips on the back
-Firestone At's , 265/75/16
-TT
-4 door leaf pack/aal/shackles
Near future:
-f150 tow hooks
Future: 3" body lift, 285/75 M/Ts
MidnightRebel07
Pittsburgh, Pa.
2003 Explorer Sport Trac
Sounds like you have a spark plug wire arcing. You can check by spraying really any liquid onto the wires when the truck is running.
sport97
Elite Procrastinator
connellsville pa
1997 sport SOHC 4.0
Pounds like you have a spark plug wire arcing. You can check by spraying really any liquid onto the wires when the truck is running.
I'll try, but they are new wires and I did experience this with the old wires. Itll happen a few days in a row, then not for a while. Its weird.
My drivers window was a causality of 4 wheeling. All the rattling around broke the window track. I opened the panel to find part of the track broken off, a snapped connector and 2 broken wires (the broken track snagged them)... I fixed the track with some jb weld, and said screw it to the wires. The wires were for the door ajar. Now my lights don't come on with my driver's door, no biggie. In a way I like it because I can turn back the key, turn on the radio and open my door without the buzzer dinging.
sport97
connellsville pa
1997 sport SOHC 4.0
My lower ball joint did not fair well off roading. The grease fitting snapped off and now I have an opening I cannot get a new fitting into. I put some gasket maker over it but it probably wont last long because there probably is no grease and its probably full of dirt and stuff too.
Replaced the drivers side hub with a MOOG. The first one I got was wrong (right number on the box, wrong part inside). Exchanged that and it went smoothly. The hub was definitely trashed but I still have a lot of noise up in the drivers front wheel. Could just be the tire but its only the drivers side...
MidnightRebel07
Pittsburgh, Pa.
Check the CV axle, noise might be from there.
sport97
connellsville pa
1997 sport SOHC 4.0
Visual on it seemed fine, not really any slop in it and no tears either. Chalk it up to a worn tire on the drivers side for now...until something breaks. I'm just glad I didn't pull out a hub that was good, it was pretty well shot.
sport97
connellsville pa
1997 sport SOHC 4.0
You've had quite the ride so far with this thing. Keep it up.
Thanks. She has been good to me, and i've had good times with her.
Just did a 400ish mile road trip this weekend.... not a comfy road trip car though...
4 people in a sport, with camping gear for 4. I was loaded to the absolute maximum. I have that road noise issue, combined with a loud exhaust around 3k rpms (which it saw alot of due to the hill climbs) caused for a noisy ride. Not to mention my a/c doesn't work so windows had to be open to get fresh air.
Even this loaded down and heavy foot driving in the mountains of west virginia i pulled 18.4 and 17.3mpg out of my 2 fill ups.
sport97
connellsville pa
1997 sport SOHC 4.0
I located the spot of my gas leak. Filler neck. It seems as if its leaking where the metal meets the rubber. I assume that is a rubber hose must be split or rotted.
Glen4X4
Lewistown, Pa
2000 XLS
That would be my guess as well. I believe JoeDirt wrote a write up on replacing it.
sport97
connellsville pa
1997 sport SOHC 4.0
I still have that gas filler issue (only leaks when topping off tank...) but i did figure out the noise!
Passenger wheel hub/bearing... I replaced it 1 1/2 yrs ago.... Autozone s**t. This part was replaced just prior to my boycott of autozone. Also need a new battery, it dies after 45 mins of radio play (crappy 3 year old diehard). Even with my **** car of the paint (wax it quite often, along with claybar etc..) I still have spider cracks and clearcoat fading starting on the hood/ fender edges :(
So here is what I need to replace on the explorer:
Windshield (has big crack) : $200
Wheel hub: $120
Tranny dipstick tube (mine is rusted): $25
New tires: $600
Filler neck (if not repairable as is) :$100
Battery (if they wont prorate my warranty) $110
Option stuff: New rear bumper(old one is rusted through with holes) $150
Fix rust/repaint rear quarter: $600
sport97
connellsville pa
1997 sport SOHC 4.0
New Moog bearing installed. That thing was shaking so bad it actually loosened the lug nuts! Nice and quiet now.
MidnightRebel07
Pittsburgh, Pa.
Glad to hear, just in time before the weather changes for the worse. gonna try and get the front bumper done tomorrow and install the new winch.
sport97
connellsville pa
1997 sport SOHC 4.0
That will be nice to finally get that on.
Im looking at new rear bumpers. Don't have fund for a custom one so I may look at 97 mounty bumper with the reflectors. Any idea where to find one?
Glen4X4
Lewistown, Pa
2000 XLS
Good plans and good to hear you fixed the bearing in time. Only places I could tell ya to try is craigslist, junkyards, ebay wanted ad and maybe ford direct parts.
Keeper0311
Riverside, CA
2000 XLT 4x4
Wheel hub: $120
New tires: $600
Always something isn't it?
MidnightRebel07
Pittsburgh, Pa.
LOL, I don't think Carol would be too happy if her back bumper went missing. We're actually planning on putting her Mountaineer up for sale soon to get a newer truck or suv for her. I'm looking for another Sport Trac for her.
sport97
connellsville pa
1997 sport SOHC 4.0
sport97
connellsville pa
1997 sport SOHC 4.0
I did get the cooper ATPs put on. So far so good. Good looking tread, but the sidewall is not aggressive looking.
The girlfriend is buying me a new windshield for christmas/birthday and Im going this weekend to pick up a cleaner rear bumper and a scratch free rear fender flare for 30 bucks too.
MidnightRebel07
Pittsburgh, Pa.
Scratch free flare, why? Just rhino line the flares and not worry about scratching your new one. The new tires look like their pretty good for all types of weather, I see their siped for ice which will help since you live in the ice valley 70 corridor. Lol.
sport97
connellsville pa
1997 sport SOHC 4.0
Because I like to pretend I won't cause anymore body damage and I'm **** lol. Ive thought about rhino lining all the plastic but I haven't committed to that yet.... the key word is yet. The new(to me) bumper is getting bedliner prior to install. At least that one wont have rust sores and holes in it. Its paper thin.
I expect these tires to be better in the mud than my firestone ATs, and I never got stuck in those.
