gavin
- September 27, 2002
- Anchorage, Alaska
- '97 Explorer XLT AWD 5.0L
So I've been... fighting and dealing with... a vibe on the junk forever.
At this point, about the only thing I haven't done anything with is the transmission.
With truck off and transmission in N, rolling the vehicle forward or back I hear a high-pitched squeal coming from the transmission. Putting my ear or a stethoscope on the transmission pan verifies the noise is coming from the transmission.
Now it's not super loud, but can be heard clearly (if truck is not running anyway.)
It was rebuilt years ago, and I know the issue came some time after that, but I cannot be positive as to when exactly the issue started.
Questions...
#1 - squeal can't be good, right? Fluid is clean, though I haven't dropped my pan in forever. I do have an aftermarket pan with a drain plug and I have drained fluid to get a look at it.
#2 - can whatever is causing the squeal, also cause a fairly consistent vibration even when coasting in N?
#3 - what internals could be causing a squeal?
I'm pretty dumb... err, uninformed when it comes to transmissions.
4R70W
Questions...
4R70W
