config
- October 2, 2000
- Layton, UT
- '96 XLT
I'm no mechanic and am having problems understanding this. Vehicle has been running rough. Changed the plugs, wires, O2 sensors and it helped a bit but still has stalling, rough idle (when cold) and bad gas mileage. Purchased a scanner and here is what I got. I don't understand what would cause Banks 3&4 to have -100% fuel trim readings. Again, there are no codes stored. Am I reading this right? Please see attached document for more sensor data.
Requesting MIL Status & DTC Count
TX: 0101
RX: 41010007E505
MIL: Off
Stored DTCs: 0
Requesting List of Stored DTCs
TX: 03
RX: NODATA
No stored trouble codes found.
Requesting List of Pending DTCs
TX: 07
RX: NODATA
No pending trouble codes found.
Checking for Freeze Frame Data
TX: 020200
RX: 4202004C51
Freeze freeze data found for C0C51
Freeze Frame: Reading Fuel System Status
TX: 020300
RX: 4203001900
Fuel System 1: OL
Fuel System 2:
Freeze Frame: Reading Calculated Load
TX: 020400
RX: 42040000
Calculated Load: 0
Freeze Frame: Reading Engine Coolant Temp
TX: 020500
RX: 42050016
Engine Coolant Temp (F): -0.399999999999999
Freeze Frame: Short Term Fuel Trim (Banks 1,3)
TX: 020600
RX: 4206007F
STFT Bank 1 (%): -0.78125
STFT Bank 3 (%): -100.78125
Freeze Frame: Long Term Fuel Trim (Banks 1,3)
TX: 020700
RX: 420700B2
LTFT Bank 1 (%): 39.0625
LTFT Bank 3 (%): -100.78125
Freeze Frame: Short Term Fuel Trim (Banks 2,4)
TX: 020800
RX: 42080080
STFT Bank 2 (%): 0
STFT Bank 4 (%): -100.78125
Freeze Frame: Long Term Fuel Trim (Banks 2,4)
TX: 020900
RX: 42090080
LTFT Bank 2 (%): 0
LTFT Bank 4 (%): -100.78125
Freeze Frame: Intake Manifold Pressure
TX: 020B00
RX: NODATA
Freeze Frame: Engine RPM
TX: 020C00
RX: 420C000000
Engine RPM (rev/min): 0
Freeze Frame: Vehicle Speed
TX: 020D00
RX: 420D0000
Vehicle Speed (mph): 0
Freeze Frame: Ignition Timing Advance
TX: 020E00
RX: NODATA
Freeze Frame: Reading Monitor Test Results
TX: 0101
RX: 41010007E505
Misfire Monitoring Supported?: Yes
Misfire Monitoring Completed?: Yes
Fuel System Monitoring Supported?: Yes
Fuel System Monitoring Completed?: Yes
Comprehensive Component Monitoring Supported?: Yes
Comprehensive Component Monitoring Completed?: Yes
Catalyst Monitoring Supported?: Yes
Catalyst Monitoring Completed?: No
Heated Catalyst Monitoring Supported?: No
Heated Catalyst Monitoring Completed?: Yes
Evaporative System Monitoring Supported?: Yes
Evaporative System Monitoring Completed?: No
Secondary Air System Monitoring Supported?: No
Secondary Air System Monitoring Completed?: Yes
A/C System Refrigerant Monitoring Supported?: No
A/C System Refrigerant Monitoring Completed?: Yes
Oxygen Sensor Monitoring Supported?: Yes
Oxygen Sensor Monitoring Completed?: Yes
Oxygen Sensor Heater Monitoring Supported?: Yes
Oxygen Sensor Heater Monitoring Completed?: Yes
EGR System Monitoring Supported?: Yes
EGR System Monitoring Completed?: Yes
TX: 0101
RX: 41010007E505
MIL: Off
Stored DTCs: 0
TX: 03
RX: NODATA
TX: 07
RX: NODATA
TX: 020200
RX: 4202004C51
TX: 020300
RX: 4203001900
Fuel System 1: OL
Fuel System 2:
TX: 020400
RX: 42040000
Calculated Load: 0
TX: 020500
RX: 42050016
TX: 020600
RX: 4206007F
TX: 020700
RX: 420700B2
TX: 020800
RX: 42080080
STFT Bank 2 (%): 0
TX: 020900
RX: 42090080
LTFT Bank 2 (%): 0
TX: 020B00
RX: NODATA
TX: 020C00
RX: 420C000000
TX: 020D00
RX: 420D0000
TX: 020E00
RX: NODATA
TX: 0101
RX: 41010007E505
