rich uk
- September 17, 2007
- surrey
- 1998 sohc 150k Purple LPG
Gent's long time since I made a contribution ,
Ex has been as good as gold for ages ( :
just did a rebuild on my starter motor as it was getting unreliable
the parts are available on ebay and is an easy job once off the car
I did dismantle the S Solenoid and fixed for free, by filing the contacts ,
you have to un fold the metal at the plastic top and drill the press fixings in the side.... makes a look a bit messy ,
then de solder the coil wires , unscrew the plastic cap- bolt / contact washer clips from the cable bolts ... not impossible to do ,
but I had ordered a new one so didn't refit it
Starter solenoid is 2 star bolts to change and will be about £15
you will need a 5mm ring / fork electrical connector and a bit of wire connected to a male spade , as the ex uses a male spade for the coil this has a bolt fixing
http://www.ebay.co.uk/itm/NEW-FORD-...arts_Vehicles_CarParts_SM&hash=item3a9006dcd0
motor brushes were half worn @ 155k
I just filed them down and cleaned
but they look same as these ..
Im sure you could use them with a little work if different
http://www.ebay.co.uk/itm/STARTER-B...arts_Vehicles_CarParts_SM&hash=item4ad2699781
test it before fitting as its possible to get it the wrong way around on the motor side
good luck guys
good luck guys
