Startup Rattle | Ford Explorer - Ford Ranger Forums - Serious Explorations
    Right now you can purchase an Elite Explorer membership for $20 and receive a two year membership! If you have an existing Elite membership contact me by PM and I will upgrade your account manually.
Startup Rattle
irocdupi
Smithtown NY
03 Explorer XLT
Ok so I hear alot of different things about what the startup rattle could be. It only does it when the truck has been sitting for a while. Usually the first start of the day when its real cold. I know its the timing chain, is it the tensioner, if so can I replace it.
Holiday Special! Join the Elite Explorers $20 for 2 years! Gets rid of the ads!
Black Dynomite
Wellington, New Zealand
2005 Ltd 4.6L
I get the same thing. swetrid reckons its normal.
gforceman
Virginia beach VA
2003 limited 4.6 V8
im assuming you have the V6 explorer , the last ex i had the ( 03 and 02 ) both did the same thing , on top of the engine front theres a hydrolic timing chain tensioner , theres a fix for the drain back of oil for that to stop the start up rattle . i never bothered with it
manaen
Clear Spring, MD
2011 Xterra Pro-4X
Yeah the fix helps a little however you will still notice a little rattle on startup. It's just the nature of the beast. When your engine starts it takes a second or two to pump up the hydraulic timing chain tensioners. I've noticed that if I park with my truck pointing down hill slightly it's not as bad (my driveway slopes a bit). But you get used to it. You only need to start worrying when it rattles while under normal conditions when running). Be sure to change the oil regularly.
RKelly2233
Rochester, NY
03 XLT 4-Door Sport
do you know what the fix is??tryin to get her back in tip top shape... i've tried searchin the threads... THERE ARE TONS to look through... I wish one would be 'sticky'ed. Got an 03 with about to hit 180... im parking her this summer if gas really gets to $5 a gallon... it was $3.40 last week here in rochester, and i heard they just went up today locally... alot... that aside, any knowledge on a thread? thanks
manaen
Clear Spring, MD
2011 Xterra Pro-4X
lookup the Ford 00m12 recall kit it includes all the parts.
RKelly2233
Rochester, NY
03 XLT 4-Door Sport
is that for gen 2 or gen 3??? I looked up recalls for my x- (03) and came up with none... at all.. is the gen 2 4.0 sohc (not the aerostar 4.0) the same as my V6? in other words- would that work??
manaen
Clear Spring, MD
2011 Xterra Pro-4X
that's for the gen2 the gen 3's already have the fix implimented. Not sure of the exact dates but I know sometime towards the end of the gen2'a (like 2000 or 2001) they included the updated in the engines. Then they made some further improvements to the system in like 02 or 03. So if you have a gen3 then you do not need the updates. If you are hearing a startup knock you may need to replace the hydralic tensioners. It's been said on here they they only last about 70k. However I think this has more to do with type of oil used and if normal change intervals are followed.
shadowless127
Long Island, NY
'01 EB AWD 5.0
my 4.6L used to do it, i believe it was the belt tensioner.
