matt88ch
- May 17, 2024
- Norwich Ct
- 2013 Ford explorer PIU
Hello everyone!
I have a 2013 3.7 PIU explorer and the steering rack went out, at first it was hard to turn once in a blue moon for a split second and over time it finally stopped working all together, fuses, wiring and power are all ok so I figured it's time to replace the rack. I got a used rack from another 3.7 PIU with low mileage and I know it needs to be programmed after it is installed. My question is, does anything like a serial number or any info need to be pulled off the old rack for a successful programming of new rack? I am a tech at a dealership(not ford) so I will do the rack replacement myself and alignment afterwords, then bring the car across the street to ford for programming. I don't want them to tell me that I had to pull some info from old rack before I removed it. Also is there anything else I should be aware of before I do the replacement?
Thanks in advance,
Matt
Thanks in advance,
Matt
