The D
- October 12, 2022
- Denver, CO
- ‘13 Explorer XLT
Reading this sept 2023 and found this very informative and accurate
Thanks for the post. Just wanted to say that it its very important when installing both valve covers to make sure you apply sealant where the 2 parts of the engine are mated together that you apply sealant along both "cracks",
Once you have the covets off you'll see where im talking about, both closer to passenger side. I speak from experience, 2016 PIU 3K after new water pump, both were leaking bad.
I had a little excess that squeezed up when the cover was tightened down but this is a good idea.
Good job, Andy. I’m glad I’ve been helpful. I’ve found that they’re definitely some aftermarket parts that should be avoided, Dorman being one of them. Cloyes, though, can be trusted imo. They’ve been making timing components for a very long time. But it’s always a safe bet on oem parts, pretty much no matter whatBig thanks to the op for this thread. I wasn't even sure if this could be done without dropping the entire engine cradle. I was going to pay to have this done, but after finding this thread, and with my work slowing up enough to allow me a little free time, I decided to give it a try.
As a previous poster mentioned, the 14 EB is quite a bit different. Mine is a GTDI and not the Ti-Vct. 2 solenoids, 2 intake phasers and 2 exhaust sprockets. I'm currently waiting on a M8x1.25 thread chaser to finish clean up. All of my cover bolts had sealant on them and I want to clean the threads up to get proper torque values. With 160k on the clock, I'm sure the timing components had been done already, but with all the parts being OEM, I have no way to know if someone had previously replaced everything, or just the water pump. I bought it used at 91k and its been a great vehicle.
I did opt to purchase all oem parts. I learned my lesson with my 5.4 3 valve on buying aftermarket parts. No Cloyes or Dorman for me as long as I can help it. The only aftermarket part is the Melling HV oil pump. It was a good upgrade on my 5.4 and I think it will be a good upgrade for my 3.5.
My serpentine belt is only a few months old but my tensioner was original. Tensioners were on backorder at the time I replaced the belt. The tensioner was a little stuck, and the alternator was a little noisy when I tore it apart. Both oem replacements are set to be here tomorrow.
I'm happy to share my list of part numbers or any info if it helps out.
