still want lift spacers? | Page 4 | Ford Explorer Forums
so how do i go upon getting some spacers from you... or are u still making a design for them ...or wat ? keep me in the loop. im really interested in some 2.25" front and 1.75" rear spacers
I should have time this week to get them drawn up and sent to the lasercutter. I will most likely do an initial run of 10 sets and see how that goes.:)
im in for the biggest you have. the x needs some lift ...
I want some!!!!!!!!!!!
i think we need pics once they are done. just my input i think the spacer will need a slight angle so it wouldn't just extend the front coilover. it should keep the coilover at a factory angle which would also make more clearance for the spindle and upper control arm. i'm sure once you take a look you will get where i'm coming from. if you need more of a picture i can try to explain it better
x2 on both subjects :thumbsup:
So i would like to order SET of the lift spacers where can i do so?
yeah so i just read all of these thread and this sounds like a good idea, now i would like to just be updated on whether the spacers are good so i can be able to order some from you brandan
SOOOOOOO.... How much? cuz im looking to buy a set here soon
I'm going to take a look soon at these, and if an angle will help, I will do it:)
ill make sure he gets on here and checks this thread..
thank you sir...
and to everyone interested, i am sorry this is taking awhile, I'm just a one-man show, juggling lots of projects. I can assure you that once these are designed and everything is ok with them, lead time will be very short on them once an order is placed...
like I said before, max lift will be 2.25" front, 1.75" rear.
That's a great combination to level the rake on these, and also not to stress the ball joints too much. It's the same combo I'm running on mine and it looks great.
When will they be available Brandon?
Good! My ball joints need replacing. I'm gonna use your sticky thread Justin.
Sounds awesome to me. I am looking for a set as well.
Will you post pics and update us?
Anybody know what size tire you could fit using these spacers?
Brandon,
Ive got my 2nd gen if you need some stock suspension to look at/ try stuff out on if you plan on doing a lift for 2nd gens ;) ....and i know a guy, Jeremy here at cal poly, that said he know you guys..?
I would def be interested in a set. Any idea how much your gonna charge and if they will come with directions?
