Sunroof Leaks (BAD!!!!) | Ford Explorer Forums
DieselHilux
95 ford contour
Got a 96 Exploder, the damn sunroof leaks pretty bad and it distroyed the headliner and it seems like the gasket has failed and is the cause.
Where is the best place to get said gasket or should I just go to the Ford Dealer???
The drain tubes are clear and it seems like its the gasket.
are you 100% sure on the drains?
If the drains are functioning properly the seal never some into play.
But to answer your question Ford is your best bet.
Have you checked the drains all the way to the exits? They can look clear and be plugged at the bottom. One of my old Tauri had a blockage exactly 1/2" from the bottom of the tube. The gaskets don't really stop water from getting in (thus the drains), they only slow down the flow...
