I've been working on this project and everything is finished except for a problem i have in wiring the factory switch. I have the LED light bar mounted and all the wires run with the provided wiring harness and tested with the provided switch, everything worked fine. The provided switch had three wires(hot, switched, and ground) so i figured it'd be an easy matter to splice the three equivilant wires into the factory switch (LB/BL, OR/TN, Black, respectively). Now when i use the factory switch the 30A fuse on the hot wire from the battery to the relay keeps blowing. I read somewhere else on the forum to connect the hot wire to something other than the battery, but i can't find anything that doesn't draw similar power. See below for the relay and a wiring diagram.....why isn't this working?
http://imgur.com/0acfGkL
