Everyone's entitled to their own opinion but mine is that Detroit Axle parts are generic chinese import junk. I'd get a major brand rotors, and pads is a long topic onto itself but I've been happy with Autozone Duralast Gold ceramics, which have a lifetime warranty so pay once and free pads for life thereafter, though I got them years ago as first replacement set so "for life" was a longer amount of time (similar major brand ceramics are cheaper on Rock Auto or Amazon w/o a lifetime warranty), and if you tow a lot then severe duty semi-metallics may be the better option.
Front swaybar end links, when (not if) my newer design Moogs fail again, I'm definitely doing it the way Swhawaii did his, already have the larger diameter sway bar bolts (lifetime replacement from Autozone but I didn't want their crap bushings so bought Moog before realizing they had changed the bushing design) but those larger diameter bolts/sleeves/washers/nuts kit can be hand in a kit on Rock auto for under $10 (plus S/H), then I'd just not use the bushings in the kit, instead those oversized Energy Suspension listed in the topic below:
i have installed on my ex the eibach sway bar kit...In the begining of the year i had to replace my sway bar link bushings because the eibach bushings that came with the kit were worn down and the links were loose... As of yesterday i have the same problem and my links are loose again...my ex...
www.explorerforum.com
