Lazzman
- June 27, 2005
- Massachusetts
- 1998 Sport 4wd- V6 Sohc
Today I made swiss cheese out of my factory Ford air filter box. It was a real messy job, plastic everywhere. I also pulled out the plastic horn part.
What was the result you ask. My engine blew up.....
Just kidding, throttle response is greatly improved. Stabbing the gas a bit from a dead stop will snap your neck back- note I am running 4.10's out back but that throttle response was not there before. When cruising performance seems increased and when you put the peddle past half way you get a loud air sucking sound like a four barrel carberator. Wide open throttle seems to be about the same if not a bit better. The whole mod took me about 1 hour and I did end up breaking the plastic mounting rods which I glued back with Krazy glue. I am running a K&N filter Charger air filter.
I would have gotten an aftermarket deal but I am flat broke. My exhaust seems to be rusting out so I will have to fix that pretty soon. I have a great exhaust shop down the road that does killer custom work, though I think I am just going to do 2.5" aluminum back with an angle cut like stock. I am looking into getting a muffler that is free flow but not super loud, maybe Flow Master or Magnaflow.
