Sync 2 to Sync 3 Problems | Ford Explorer Forums
Andrew H
Columbia, SC
2016, Explorer Platinum
I recently upgraded my sync 2 system to an aftermarket sync 3 system and it works fine expect for the fact that my steering wheel controls and voice commands no longer work. Does anyone know a solution in forscan for this?
Welcome to the Forum Andrew. :wave:
I don't use FORScan as I lease my vehicles, but I'm sure that someone will be able to assist you.
The Sync 3 APIM is not programmed properly for your vehicle
i actually did some messing around in forscan and was able to get it working but thank you for the input none the less
Details please!
Details please!
idk if this works for every vehicle but in Forscan In the APIM(AS BUILT Format) I just pressed on the Load Factory AB after I tried something from a video to get my climate control working again but it ended up fixing my wheel issue as well
