SYNC 3.4 Most recent version? | Page 9 | Ford Explorer - Ford Ranger Forums - Serious Explorations
N3DD
2020 Explorer Limited
From memory you can just run that interrogator by itself. It's the last package in the list in the autoinstall.lst. You can just edit that to run only the final package and see if it kicks out the XML then.
Don't know how to open these files. Any harm in just reinstalling the whole package?
UofMEngineer
Michigan
20' Escape Hyb Titanium
None. It’ll skip over everything that’s already installed anyway.
northvibe
2020 Ford Explorer XLT
Currently on the Ex
3.4 Build 19274
I plugged in the usb (used for updating the focus and escape before) and it "failed". Then when I plugged it in again, it just said update will install when the car starts again...weird.
New file downloaded from ford:
5U5T-14G381-EK
EDIT: Just noticed this said to format to exfat which is new for sync 3 this gen? It was always fat32 before.
Trying again
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
I downloaded the update to my USB drive as the WiFi OTA loading progression bar on the Sync 3 screen hasn't changed in over a week. Sitting at 50%. Now I just need a 30 minute drive to load it into the vehicle. :)
northvibe
Same error.
LST_ERR05
If I unplug and plug back in I get the 2nd pic saying it will install when the car restarts.
EDIT: here is the autolist contents for my XLT non nav
; SYNC3 Consumer Assembly Upgrade - Release 3.4.50 - Only for NonNav/NonEU assemblies.
[SYNCGen3.0_3.4.20282_PRODUCT]
Item1 = HB5T-14G386-VEB
Open1 = SyncMyRide\HB5T-14G386-VEB.tar.gz
Item2 = HB5T-14G386-VAB
Open2 = SyncMyRide\HB5T-14G386-VAB.tar.gz
Item3 = 5U5T-14G381-EK
Open3 = SyncMyRide\5U5T-14G381-EK.tar.gz
Item4 = 5U5T-14G391-BM
Open4 = SyncMyRide\5U5T-14G391-BM.tar.gz
Item5 = 4U5T-14G423-BB
Open5 = SyncMyRide\4U5T-14G423-BB.tar.gz
Options = AutoInstall
[SYNCGen3.0_ALL]
Item1 = GB5T-14G386-AD
Open1 = SyncMyRide\GB5T-14G386-AD.tar.gz
Options = AutoInstall,Delay,Include,Transaction
peterk9
Staff member
Moderator
Callsign
VE3
The 2nd screen usually comes up after a successful installation. Have you restarted the vehicle and checked the latest version number?
UofMEngineer
Michigan
Same error.
LST_ERR05
[SYNCGen3.0_ALL]
Using a Mac by chance? The second pop-up is because it failed the first time and it sees the same install so it’s immediately “done”.
northvibe
yes, still old.
Yes, using a mac. Should I use the 3rd party software to format?
EDIT:
Found this method to format/create. Just finished transferring. I'll go test shortly. This method uses the terminal to format the usb, then also terminal to extract the zip to the usb
EDIT 2:
Ex is currently updating via the method from Edit 1. Same usb stick. well....it is just sitting at "updating" at the top banner, so I'll let it sit 30min.
TBill
Prescott, AZ
2020 Explorer Platinum
Mine failed on the first try after downloading from my Mac, then dowloaded from a PC that I have, and the update installed. It created the log file which I then uploading on the Ford Sync Update web site.
northvibe
Update successful. Sync about shows the new build.
I'll have to remember the manual method listed above for all mac things.. In the pinball updates it is also an issue with fat32 and macs etc.
TBill
Prescott, AZ
Keep in mind when you start this update on your vehicle it is going to take 25-30 minutes to complete.
TBill
MM07
MA
2018 Explorer Limited
I have a usb saved just for updates. I formatted it on a PC I think and build manually in the Mac.
northvibe
Ya, that’s how the stick was when I did the focus rs, escape and f150. However it was fat32 🤷 all working now!
TBill
Prescott, AZ
I am wondering what the update did, I really don't see any dramatic changes so far.
TBill
northvibe
The audio side looks better. I wonder if the Bluetooth functionality was improved as it was sucking bad. Favorite phone wouldn’t be priority etc
MM07
MA
I guess I need to snoop around and see what’s different.
Didn’t notice much from 20237.
Sgt1411
VanBC/GoodyearAZ
2021 Explorer ST
Callsign
PRINCE51
I see all these vehicles are 2020 MY, anyone with a 2021 get this update?
Mine says no update available Build 20136 is the latest.
themishmosh
NE Ohio
2020 Explorer ST
This update is for all Sync 3.4 across all Ford model lines.
UofMEngineer
Michigan
It's possible they haven't switched it on for MY21 programs as of yet.
peterk9
Staff member
Moderator
Callsign
VE3
Software update installed. 30 minutes to update. Successfully reported update, or so it said. ;)
