SYNC 3 in a 2016 Explorer | Page 16 | Ford Explorer Forums
dead thread? I was thinking about going to a junk yard and pulling one from an F150 or another Explorer. Would those work? is there a list of part numbers that are compatible? Trying to get the best deal possible.
The thread is not dead. Usually, a lack of response is due to members not being able to answer the questions posted.
Update:
I upgraded my 2016 Explorer Platinum to Sync 3 using a module I bought off Marketplace (seller said it was from a 2019 Fusion, but I think it may be from a Focus). It had Android Auto and CarPlay, but factory features like massaging seats, heated steering wheel, etc., were missing.
I grabbed the VIN-based As-Built file from Ford’s site and used Forscan with an extended license to flash the APIM. I got a warning about block lengths not matching but continued anyway. Flash was successful, and now most factory features are back.
However:
TPMS pressures don’t show on the dash (not sure if they ever did).
Getting some voltage-related DTCs — we had a weak battery before the swap, now charging it and planning to clear codes.
Currently running Sync 3.0 — wondering if it's worth updating to 3.4.
Any tips on restoring missing features, clearing DTCs, or safely upgrading to 3.4?
This is the APIM part number I installed.
JS7T-14G371-JHD
Also as a win so far I am in $230 on this Sync 3 upgrade.
This is my current APIM calibration:
APIM - Accessory Protocol Interface Module
Part number: JS7T-14G371-JHD
Calibration level: JS7T-14G371-JHF
Strategy : HB5T-14G374-CA
Calibration: HB5T-14G375-BA
These are the codes that will not clear:
===PCM DTC None===
Successful DTC reading, no error codes found
Module: Powertrain Control Module
===END PCM DTC None===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===APIM DTC U3003:16-0B===
Code: U3003 - Battery Voltage
Additional Fault Symptom (:16):
- Circuit Voltage Below Threshold
Status (-0B):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Accessory Protocol Interface Module
===END APIM DTC U3003:16-0B===
===PAM DTC U0420:00-2B===
Code: U0420 - Invalid Data Received from Power Steering Control Module 'A'
Status (-2B):
Module: Parking Aid Module
===END PAM DTC U0420:00-2B===
===BdyCM DTC None===
Module: Body Control Module
===END BdyCM DTC None===
===DACMC DTC U3003:16-0A===
Status (-0A):
Module: Digital Audio Control Module C
===END DACMC DTC U3003:16-0A===
===SODR DTC None===
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC None===
===SODL DTC None===
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC None===
===HUD DTC None===
Module: Head Up Display
===END HUD DTC None===
===IPMB DTC None===
Module: Image Processing Module B
===END IPMB DTC None===
===FCIMB DTC U3003:16-08===
Status (-08):
- Previously Set DTC - Not Present at Time of Request
Module: Front Controls Interface Module B
===END FCIMB DTC U3003:16-08===
===ATCM DTC None===
Module: All Terrain Control Module
===END ATCM DTC None===
===RHVAC DTC U3003:16-08===
Status (-08):
Module: Rear Heating Ventilation Air Conditioning
===END RHVAC DTC U3003:16-08===
===DSP DTC None===
Module: (Audio) Digital Signal Processing Module
===END DSP DTC None===
===SCME DTC None===
Module: Front Seat Climate Control Module
===END SCME DTC None===
===RGTM DTC None===
Module: Rear Gate/Trunk Module
===END RGTM DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===C-CM DTC None===
Module: Cruise-Control Module
===END C-CM DTC None===
===ABS DTC None===
Module: Antilock braking system
===END ABS DTC None===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===DSM DTC None===
Module: Driver's Seat Module
===END DSM DTC None===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC None===
Module: Drivers Door Module
===END DDM DTC None===
===RCM DTC None===
Module: Restraint Control Module
===END RCM DTC None===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===PSCM DTC None===
Module: Power Steering Control Module
===END PSCM DTC None===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC None===
Module: Instrument Panel Control Module
===END IPC DTC None===
===GWM DTC None===
Module: Gateway Module A
===END GWM DTC None===
===HSWM DTC None===
Module: Heated Steering Wheel Module
===END HSWM DTC None===
===SCMH DTC None===
Module: Passenger Multi-Contour Seat Module
===END SCMH DTC None===
===SCMG DTC None===
Module: Driver Multi-Contour Seat Module
===END SCMG DTC None===
===IPMA DTC None===
Module: Image Processing Module A
===END IPMA DTC None===
===GPSM DTC None===
Module: Global Positioning System Module
===END GPSM DTC None===
