SYNC 3 latest version
ilguy
Chicago
2017 Explorer Platinum
I was previously an early adopter to the "unofficial" version 3 build number 17276 found on another forum. After attempting to update to the OFFICIAL version 3, I would get a message that I already had the current release. I then downgraded to version 2.2 and completed a master reset. Once confirmed that 2.2 was running fine, I performed the OFFICIAL version 3 update and successfully installed SPECIFICALLY FOLLOWING the directions from the Ford Owner site. The final outcome is version 3.0, Build 18025. All updates were perfomed using the center console USB jack. Don't forget to log back in to the ford owner site and update it with the .xml file from the USB stick you used. That will update your owner portal with official version info.
So far, I've noticed much better bluetooth connectivity to my Iphone X which was becoming very unreliable on the 17276 build. That in itself makes the exercise worthwhile.
Hope this helps!
(here is where I found the v2.2 for the downgrade: NAV Sync 2.2 update-download site - Ford Truck Enthusiasts Forums)
peterk9
Staff member
Moderator
2020 Aviator Reserve
Callsign
VE3
.........Don't forget to log back in to the ford owner site and update it with the .xml file from the USB stick you used. That will update your owner portal with official version info.
I tried that several times after updating to V2.3 and each attempt was unsuccessful. Gave up and after a few days I noticed my account was updated with the successful update. It had have done it through the WiFi connection sometime while parked in the garage.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Apparently, the way you tell if you have had a successful over the air WiFi download is by displaying the WiFi symbol in the top right corner with an arrow facing down through it.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Hope this helps!
I downloaded v2.2 to a 64GB ExFat USB drive, unzipped the 4 files but the SYNC 3 v3.0 wont recognize the files as a new download. SYNC3 just says "USB Indexed"
File type on the USB for the 4 files is GZ.archive
ilguy
Chicago
Try a master reset first....
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Formatted the USB and started again.......your process worked properly this time. Did both Explorer and Focus with the downgrade to v2.2 and then upgrade to v3.0 ....thanks.
ilguy
Chicago
Great news Sgt411! I’ll be interested to hear what improvements you find.
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
I had similar issues you had with iPhone, spotty phone connectivity, the call would display for 1-2 rings on iPhone8 before SYNC3 displayed anything to enable handsfree answer. Also initiated SYNC3 call several times and upon call connectivity, the audio was all garbled. I'm hoping both of those are now gone.
Location
Plant City
Plant City, Florida
2017 Explorer XLT
Updated to V3.0 via USB this morning. Used my old Windows Vista laptop for download to USB. Successfully installed into vehicle. Returned to laptop & reported install to Ford.
Changes? Screen does show 3.0 installed. I'm an Android user, & it worked perfectly before, so I'm hopeful it will still work the same next outing.
peterk9
Staff member
Moderator
Callsign
VE3
Updated to SYNC3 via USB this morning. Used my old Windows Vista laptop for download to USB. Successfully installed into vehicle. Returned to laptop & reported install to Ford.
I believe you meant you update to V3.0, not SYNC3.:) Good to hear everything went well. Going to give mine a try tonight as I have 25 minute drive to make.
Location
Plant City
Plant City, Florida
2017 Explorer XLT
Yep, that's what I meant to say, and edited same. Sharp eye you have there!!!
Sgt1411
VanBC/GoodyearAZ
2017 Explorer SPORT
Noticeable improvement of BT connection between phone and SYNC3, faster phone sync, faster call connection, better audio quality.
peterk9
Staff member
Moderator
Callsign
VE3
........... Going to give mine a try tonight as I have 25 minute drive to make.
Updated to V3.0 successfully last night. Update took 16 minutes. Reported it successfully as well but my account still shows V2.3 as my latest. Will check it again later. First thing I noticed was that there is now the ability to turn ON/OFF the heated steering wheel from the 'Home' screen.
Location
Plant City
Plant City, Florida
2017 Explorer XLT
Peter, I already had that option prior to this update. I was out on errands this morning but unlike you northern folks, it wasn't cold enough here in PC to use any type of heat in vehicle. Am I sad about that? Not!
peterk9
Staff member
Moderator
Callsign
VE3
Interesting. You say you had that ability on the Home screen with V2.3? The only thing I had was the heated steering wheel picture noting it was ON. To actually turn it ON/OFF I had to go to the Climate screen. BTW, it's a balmy 42 degrees F here now. Digging through the closet to find my shorts.:D
peterk9
Staff member
Moderator
Callsign
VE3
Does anyone else get the following message every time they start the car?
"SYNC can check for updates when connected to a Wi-Fi network."
It then gives the options to view networks or close. I went into the settings and turned off Wi-Fi but the message still comes up.
I had that message come up once after the update and after I closed it, never saw it again.:dunno:
Location
Plant City
Plant City, Florida
2017 Explorer XLT
Peter, right again. Heated steering wheel was visible but to turn it off did require going to climate screen.
Zodiac
2017 Ford Explorer Sport
I'm not sure what is going on, I get it every time I start up.
I have verified that wifi is disabled in settings...the only thing I have yet to do is actually connect it to a network but I'll try that this weekend.
Lewisra
Howell, mi
2017 explorer limited
Hope this helps!
Any secrets to the downgrade, I've tried 2 separate USB's formatted in Fat32 and then exFat can't get anything other than indexing USB. This is on my Focus, SGT1411 didn't mention you were able to do it on yours?
G Will ford release Sync V 3.4 on the Explorer 2017+ Sync 3 / In Vehicle Technology 39
B sync 3 updated via wifi - how do I report successful update? 2017+ Sync 3 / In Vehicle Technology 4
D 2017 Explorer..Sync "indexing" 2017+ Sync 3 / In Vehicle Technology 1
Y Sync 3 Map Upgrade Issue 2017+ Sync 3 / In Vehicle Technology 24
T Nav/Sync System Problem 2017+ Sync 3 / In Vehicle Technology 12
R New Sync Update JRT3-14G381-AS.zip. Any luck? 2017+ Sync 3 / In Vehicle Technology 12
Y Sync 3 v3.0 Bluetooth, Aux Line In or USB Storage Alternatives 2017+ Sync 3 / In Vehicle Technology 2
expoman55 Sync Lastest version - ford pass et al 2017+ Sync 3 / In Vehicle Technology 1
dlphnfn Incoming call to Sync 3 w/ Pixel 2 2017+ Sync 3 / In Vehicle Technology 0
D Sync 3 problems. APIM? 2017+ Sync 3 / In Vehicle Technology 2
Z Sync V3.0 to V3.4 Upgrade 2017+ Sync 3 / In Vehicle Technology 154
B Sync 3 still dropping my phone 2017+ Sync 3 / In Vehicle Technology 16
T Sync screen blank sometimes. 2017+ Sync 3 / In Vehicle Technology 1
B Sync 3 bracket modification 2017+ Sync 3 / In Vehicle Technology 3
Bobs2018Explorer Upgrading basic non-Nav 4" Sync to 8" Sync-3 with Navigation 2017+ Sync 3 / In Vehicle Technology 2
D What version of Sync do I have? 2017+ Sync 3 / In Vehicle Technology 3
A SYNC Entertainment 2017+ Sync 3 / In Vehicle Technology 2
L Sync 3 Issues 2017+ Sync 3 / In Vehicle Technology 3
B Bluetooth issues with Sync 3 2017+ Sync 3 / In Vehicle Technology 4
ddaniel13 Sync 3 apps youtube 2017+ Sync 3 / In Vehicle Technology 1
B Sync 3 FINALLY updated 2017+ Sync 3 / In Vehicle Technology 5
B Sync 3 issues 2017+ Sync 3 / In Vehicle Technology 7
L Sync 3 - No GPS or AM/FM Radio ? 2017+ Sync 3 / In Vehicle Technology 14
B Sync 3 Mic Location 2017+ Sync 3 / In Vehicle Technology 2
M CarPlay and SYNC 3 Nav? 2017+ Sync 3 / In Vehicle Technology 6
J Stopping Sync notice on vehicle start 2017+ Sync 3 / In Vehicle Technology 2
S General Sync 3 Impressions 2017+ Sync 3 / In Vehicle Technology 4
B Sync 3 NAV & Bluetooth 2017+ Sync 3 / In Vehicle Technology 1
M Navigation Sync 3 2017 Explorer question 2017+ Sync 3 / In Vehicle Technology 3
A Newbie to Infotainment- Where to start with setting up Sync 3? 2017+ Sync 3 / In Vehicle Technology 10
E Newbie - Sync 3 question 2017+ Sync 3 / In Vehicle Technology 2
B Failed Sync update 2017+ Sync 3 / In Vehicle Technology 9
A Sync 3 GPS only allows 50 favorite destinations 2017+ Sync 3 / In Vehicle Technology 4
2 Touch Screen/Sync acting up 2017+ Sync 3 / In Vehicle Technology 8
J Sync 3 Home Screen - Removing Heated Steering Wheel opt. 2017+ Sync 3 / In Vehicle Technology 1
S Sync 3 flaky 2017+ Sync 3 / In Vehicle Technology 5
B MFT to Sync 3 upgrade success... but some remaining issues 2017+ Sync 3 / In Vehicle Technology 34
C Sync 3 3.0 - Turns Radio off after using Android Auto? 2017+ Sync 3 / In Vehicle Technology 1
C sync 3 3.0 ... no waze support? 2017+ Sync 3 / In Vehicle Technology 37
Gilbert M Vega ?? On 2018 explorer sync 3 navigation. 2017+ Sync 3 / In Vehicle Technology 5
J Ford Sync (not Sync 3) software update will not recognize USB drive 2017+ Sync 3 / In Vehicle Technology 38
P upgrading-2016-explorer-to-sync-3-forscan-questions 2017+ Sync 3 / In Vehicle Technology 0
S Sync Connect - wifi hotspot 2017+ Sync 3 / In Vehicle Technology 8
H Sync 3 and quick charge 2017+ Sync 3 / In Vehicle Technology 2
B sync 3 which maps are installed? 2017+ Sync 3 / In Vehicle Technology 25
L Alexa now on Sync 3 2017+ Sync 3 / In Vehicle Technology 1
S 2017 Rear DVD entertainment System Slimline 7 auxiliary on Sync Help Needed 2017+ Sync 3 / In Vehicle Technology 2
J How often does Ford release SYNC software updates? 2017+ Sync 3 / In Vehicle Technology 12
N Sync 3 able to play videos? 2017+ Sync 3 / In Vehicle Technology 3
D Siri not letting me use Sync 3 Voice Navigation! 2017+ Sync 3 / In Vehicle Technology 2
Similar threads
