4.0Rerolpxe
- February 15, 2008
- Starkville, Ms
- '93 Limited 4x4
which is better for higher milage vehicals my x has 160,000. is there a difference in hp, or mpg?
good point, wouldn't want to go poking holes in my motor
its really depends..i mean if u have never used synthetic oil in that truck..i wouldn't suggest using it now. YEs its better than regular oil but it also might clean up where theres oil build up and possibly cause an oil leak.
Personally i would go w/ high mileage oil. My old truck had 90k miles and i really wanted to use synthetic but just used gtx hig mileage and never had any problems
I like many others used a synthetic blend once, it made my oil leak 10x worse. .
And if a leak started I would think it's time to change that gasket since it's obviously failing, not time to put an oil in that will hide your weak points in the motor.
Amsoil, Royal Purple are some of the better or best to use. Mobil One and the others are alright but not suggested for extended use.
Hmm I was bout to pose this same question in this forum. I have a 94 with 85k on it and do not know if I should use the castrol or mobil 1 still. I have no oil leaks that I know of.
