Fuel for the fire
Pro's
Cheap and easy way to fit tires. Especially on a 2nd/3rd gen.
Not all together that difficult, though time consuming.
Changing spark plugs is so easy
hmm that's it..........
Con's
As 410 noted alot of things are stretched due to the changes in engine position. I relocated many a wire cable etc... or extended hoses. It's still an ongoing thing as I notice new areas. :thumbdwn:
Watch that A/c Line!!!!!!
Steering.....for some it works for others it doesn't. A bit of tinkering will fix most issues. But a Flaming River steering shaft will easily cure any stress/breakage concerns as well as correct the angle.
Bumpers.. no really... they do suck.....at least with handtools.
My current tool selection would make it an easy job, though still a couple hours for both.
Looks...............frame hangs to low....shackles/spring hangers/tortion bars/ front crossmember/etc..... it's just.... well obvious. Me I didn't care at the time because I wanted 33's. Now well I just want the frame further from the ground.
It's decieving I look out the window and go ,"Cool still have 4" from that rock." suddenly crunch ....
In a way this is good because my body doesnt take breakover hits, just my frame and brakelines
And lastly yes it is tricky to top off the gas tank
And I can spot one from across a parking lot, but I know what I am looking for, and look closely at the rare lifted X's.
All in all I have a BL, installed it in my garage, and I don't like it that much. Nor did I enjoy installing it, though it wasn't all that hard. I'll keep it for now because functionally it is not a problem, and IMO an IFS lift kit is not much better.
When and If I get around to taking the axle down from the rafters and doing an SAS. I'll remove the body lift, and smile as I sell it to some new guy with a 2nd gen and on a budget. Then I will giggle as this subject gets started on it's next great cycle.
