mweiss
- November 5, 2002
- New Milford, CT
- 1998 & 2006 Explorers
I received a reply from Sylvania/Osram regarding why no retrofit kit is available for the Explorer. I felt the answer was a bit muddled as to why they couldn't come up with a reflector/lens assembly, but was left with the impression that it was market/economics-driven.
Here is their response:
Mark,
Thank you for your inquiry. The only HID Xenarc kit that will fit your
Explorer is the X1010, which is the Low Beam Auxiliary kit. This kit
does not replace your existing headlamps as you know, but instead, works
in conjunction to them. It is a very powerful lighting system that is
mounted under the bumper, and will look like a custom fog lamp
application. That is the only kit we make that would fit your car.
The reason we don't have an HID kit specific to the 98 Explorer is that
your current lighting assembly that is part of your car (the lens &
reflector), is designed around a halogen capsule and you can't put a
Xenarc light source into that assembly without causing problems. Since
your assembly is specific to just the Explorer we would have to make a
kit that fits just the Explorer and at this point in time we don't have
a kit for every vehicle's headlamps. The F-150 kit fits the Expedition
of the same model years because they have the same teardrop headlight
design that the Explorer's do not. I'm in the same boat with my 94
Explorer. I am unaware of future plans to extend the Xenarc line to
include the halogen capsule configurations, but if market demand changes
I believe we may very well explore that option. Tooling costs to switch
the machines and research and development costs alone are very cost
prohibitive with any new product line, they are multiplied exponentially
with a high end line like Xenarc!
Your other option, is using the Silverstar product- 9007ST. While this
is not an HID Xenarc product (it is still a halogen product), it is very
high in color temperature @ 4000 degrees kelvin. The X1010 auxiliary
low beam HID kit is 5400 degrees kelvin, most low beam HID headlights
start around 4100 degrees kelvin and as a point of reference, sunlight
is around 5000 degrees kelvin. Using both the Silverstar product and
the X1010 can create an intense, crisp white seamless look. Both can be
purchased through our website, or you can call 800.729.3777 and I can
assist you with the order as well. Please let me know if you would like
product literature on either Xenarc or Silverstar, I am happy to mail
some to you.
I hope this information helps,
Hannah
Mark,
some to you.
Hannah
