The mutilation of my '91 thus far. :-D | Page 3 | Ford Explorer Forums
Very Creative.....
I like it!!!! You for sure will have one of a kind. Which makes it unique. Using old school technique (hanging & banging) some what of a loss art. Which makes you a "craftsman" in my book. Hope you feel better to soon, good luck on finishing the project....waiting to see.
On a side note: My Grandfather was a Blacksmith, maybe thats the connection. If you need it make it.
Thanks for all the words of encouragement and well wishes. Be kind to your back, sciatica is no fun for anyone.
I'm hoping to finish up the right fender and install the hood pins today. I'll be out of town from tomorrow to Saturday so hopefully I'll be able to get all the metal work done on Sunday (other than the left fender, need to get some more sheet metal).
~Rev
I like how this thing is turning out.
Are you going to move the headlights up a little higher? I think it would look better.
What size tires are you going to run on it?
I think some 33's would look good on it and you probably won't have a problem clearing them with no lift with your custom frontend.
This project is fantastic...it gives me hope that I can indeed narrow the front of my explorer someday.
Mini Update
Got back this morning from out of town and went out to the garage to see what I can get done.
So far I've finished up the right turn signal bezel and finished up all the welding to make the bezel and fender one piece. Also got the turn signal mounting bracket made and installed. The right side of the vehicle is finished! (well, I still need to raise the headlight and bolt on the fender, but the fab stuff is done!)
I was going to finish up the hood (bump stop thingies and hood pin leashes) but I realized that the hood pin clips I have are garbage. So Now I'm off to make a return and find a better replacement.
I'll throw some pictures up later tonight when I'm finished for the night.
~Rev
Picture Update
A day late, but here is where I'm at right now. I would have gotten more done tonight but it's a bit brisk and I ran out of kerosene for the heater.
I needed to cut the doghouse skin to match the front edge of the hood.
Then I had to make some brackets for the hood pins.
I used 1.5 inch angle iron for these.
Also, I'd like to introduce my bestest friend.
I wanted to finish up the right fender so I started by welding the seam where the turn signal bezel meets the fender. It took me a couple inches but I think I'm getting the hang of this whole welding thing.
I welded inside and out, then ground it smooth.
The next thing to tackle was the mounting brackets for the turn signal. I forgot to snap pictures while making them so I just got a few with the light installed.
There are two brackets, one slotted to accept the factory mounting tab.
And one L shaped bracket with a nut welded on the back.
Then I needed to wire the lights into the harness. Luckily I thought ahead and had plenty of length to connect them.
The last thing to do was cut an angle at the back edge of the bezel.
I also moved the headlights up a few inches and in doing so managed this.
I was really happy that I had a brand new set of irwins I hadn't opened yet so this wasn't a major set-back. =]
The fender is a multi-purpose part. It serves well as a frosty beverage holder.
And also as a work bench.
And here's a video just because I was far too excited when I finished the wiring. (crappy phone camera)
The last thing I did today was make a bracket for the ignition brick. I just cut a 3.5x4in piece of 18ga sheet and drilled a couple holes to accept the nubbit thing on the brick and a machine screw with the nut welded on the back.
Then I just welded the plate to the right hood pin bracket.
The combination of the sub-par welding ability and a mask that kept fogging up resulted in a less than pretty weld, but I'll re-weld it the next time I have the skin off.
And that's pretty much it for tonight. I'm hoping I can score some more sheet tomorrow so I can hammer out the other fender.
Being this close to the end is bittersweet. On one hand, she'll be done and I will be a very happy camper. On the other hand, I'll have to pay registration and back-fees...
Oh, on a side note, does anybody know what can be done to level the front end out after doing a spring over axle in the back? I know this is the wrong forum and there have been posts about this, but I have yet to find a definitive answer and I thought I'd just ask.
~Rev
Finished bumper; Picture Update
Sorry if the updates are getting a bit boring. It's going to be little things here and there until I get more sheet metal (hopefully by the end of the week).
Last night I was able to bolt on the fender. I drilled 8 holes along the lip that meets the doghouse.
Then I clamped it in place, made sure it was straight and level and marked for the holes in the doghouse. Then I just bolted it right up.
Yay for no more clamps!! :D Still gotta drill the two holes to bolt it to the front quarter block-out.
Tonight I got to working on the bumper. The first thing to do was to just shorten it and cut off the angled braces that go from the mounts to the original ends of the bumper. (I did this a few days ago)
The next picture shows the hacked mounts.
Then I needed to cut the ends at an angle. There wasn't really any measuring for this, I just kind of winged it and matched it up by eye.
After I got the angles where I liked them, I made a cardboard template by tracing around the edge onto cardboard.
Then I traced the template onto the sheet metal and cut out the rough shape along with two tabs to make welding it easier.
Next I clamped at the tabs to make sure it was all lined up and welded the tabs and all the way around on the inside.
I left so much overhang in case I needed to run a weld on the outer edge. (Turns out I didn't}
After it was welded I cut/ground the excess off.
I also tried to get it to match up with the plastic insert as best as I could.
I was eventually able to get the metal to match up with the plastic almost spot on. So now here's the end result.
It bugs me to no end that I couldn't straighten out the bumper where it got bent down a bit. I even tried the mini sledge to no avail. Oh well, this is just a temporary bumper until I get some more square tube.
I also tried making the front corner plates to cover the gap in the doghouse skin using the same "hang and bang" (heh, I like that term, thank you bcbid) but I ended up with a bowed piece of metal. :mad: Guess I'll just have to have it done on a break.
~Rev
I think that bumper looks good, considered sticking with it? Pretty cool watching this whole thing progress, keep it up.
Thanks. The plan is to make a bumper from square tube, but I am starting to think of ways to add a winch into this one. Now that I got the ends welded up, it's kind of growing on me. I've been trying to incorporate notable explorer bits here and there (hood, turn signals, quarter panels) and this bumper adds a lot in that aspect.
I'll be sketching out some tube ideas and some ways to add a winch to this one. If I do decide to keep the chopped stock bumper, I think I'll grab another one from the wrecking yard so I won't have to look at that dent. :p:
~Rev
Like Keeper, I also think the bumper looks good. But square tubing might be easier to hang a winch on.
Subscribing-I Like it-definitely Unique!!
I wonder if there is some kind of "bumper in front of wheels" law. Although there's alota hot rods that don't have bumpers at all.
Picture Update 12.2.10
Well, I didn't get as much as I would have liked to tonight. I ran out of gas for my welder and I supremely suck at welding with the core wire stuff (Can ya tell I'm not a welder. :p )
There was one thing that's been bugging me that I haven't addressed yet. The exposed body mount bolt.
So after staring at it for a while, I came up with a plan. First I had to make a sort of cover piece.
Once I got it looking how I wanted, I held it in place and made my marks on the doghouse and body mount plate.
Making everything removable is really paying off as I put this thing together. (though, I just left the fender bolted on, didn't feel like taking out 8 more bolts, heh)
Then I made my cuts.
Moving back to the plate I had shaped, I drilled some holes along the mounting tab to weld in.
Then I welded it up and put the skin back on the frame. (I had also cut along my line on the body mount plate)
It will be capped in, I made a template already.
I'm not sure if I want to keep it like that and cap it, or if I want to cut the top edge down at an angle, then cap (Input on this would be appreciated :) ). I'm getting more gas tomorrow so I should be able to finish this and do the other side.
Also,
I'm not aware of any laws regarding bumper width, I believe you do have to have a bumper (when the cops around here get bored, they write tickets for people with roll pans on their truck). I've seen quite a few trucks rolling around with bumpers only as wide as their frames. I guess I'll find out eventually.
~Rev
Bumper law
I got curious so I looked it up.
Taken from CA Vehicle code 28071
"Every passenger vehicle registered in this state shall be equipped with a front bumper and with a rear bumper. As used in this section, "bumper" means any device designed and intended by a manufacturer to prevent the front or rear of the body of the vehicle from coming into contact with any other motor vehicle. This section shall not apply to any passenger vehicle that is required to be equipped with an energy absorption system pursuant to either state or federal law, or to any passenger vehicle which was not equipped with a front or rear bumper, or both, at the time that it was first sold and registered under the laws of this or any other state or foreign jurisdiction."
Doesn't mention anything about width etc.
~Rev
I think for the time being, I'm just gonna cap it as is. I plan on installing a plug for jumper cables (something like this, hopefully I can find the plugs and make it myself, this kit is pretty pricey) in this piece so I need to get that and see how big it is. If I change my mind, I can always just cut an angle and re-cap.
~Rev
Edit, found where to get the plugs for cheap. =] google is my friend.
Got gas for the welder today. Gonna finish up the body mount covers. I've decided that the right side cover will contain the power plug for jumpers (can also be used to winch power) and the left side will contain a quick connect for the compressed air.
I got to thinking, does anybody know of flush mount, or even just low profile air quick connects? I searched but found nothing online.
Anywho, time to get welding.
~Rev
