Explorer Forum Covers the Explorer ST, Explorer Sport, Explorer Sport Trac, Lincoln Aviator,
Mercury Mountaineer, Mazda Navajo, Ford Ranger, Mazda Pickups, and the Ford Aerostar
Register Today It's free!
You are using an out of date browser. It may not display this or other websites correctly.
You should upgrade or use an alternative browser.
The rig gets some much needed TLC
- Thread starter Josh S.
- Start date
Add an avatar, upload photo attachments, and more!.
Josh S.
can't kick the habit
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Josh S.
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Well since I sold my old truck that was the DOM hauler, we had to make a new lumber rack for the toyota...literally...
Seriously redneck I know, but it actually worked out really well and it took us a couple of hours to build, with some free scrap wood from work. Cheap and removable. My buddy said he got a lot of wierd looks driving through Seattle lol.
Got the D-pillars done..
Got one of the lower door bars in. The 1.5" die will be in by the time I'm up there again so I can work on the seat mounts.
Josh S.
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Added window V-bars
Added tubes between D and B pillars where shock mounts will connect
I'll be working on the rig plenty now as I've moved back into town...stay tuned.
Josh S.
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Anyone, Bueler?
Here is what I have been working on the last few days...
Beefed up the windshield area...
Made some super dank and sick russian sickle gussets...
Tacked in...
Nice cleaned up shop with customers Jeep...(yah that's our crab pot up there)
She is coming along...
Need a rear axle and bypasses SOON!!
Tacked in...
- May 3, 2003
- Smithville/Austin, Tx
- 08' Suzuki SX4
Would be nice to see a closer picture from the driver's side how your working around the master cylinder/booster assy.
Other than that great looking work!
Jeff - :navajo:
Jeff - :navajo:
- February 11, 2001
- Red Bluff, Ca
- 1975 Ford Bronco 4x4
Keep it up EZJ.
Least you'll be able to get a lot done of this project now.
Josh S.
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Thanks Johnny! I'm getting a severe case of cabin fever so I'm going to come down to Chico for a week or so and have a good time dirtbiking and cheering on some graduating friends. Job searching sucks the fatty.
We should meet up and have a cold one if you are still in the area.
I'm definitely gonna stop at Del Taco in Red Bluff on the way down and up!
IZWACK- Yah I like that pic too. It portrays my tennis bag nicely right before it fell 10ft off the shelf onto the concrete floor haha.
SVO- there is barely any room between the master cylinder and the coilover...that was the whole idea behind me making those wierd looking shock hoops, but I'm not really comfortable with the clearances. I should have just went full-bore from the beginning but I was trying to keep the stock core support for some reason...I'm planning on scrapping the stock brake, clutch and steering assemblies leaving only the stock gas pedal, and going to a CNC setup. It's another situation I need to overcome. Something like this...(not my truck)
Thanks for the comments, I'll have more updates when I'm back from a much-needed vacation!
Josh S.
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Well I am back from my excellent 3 week vacation and back to the shop. Had a nice time visiting friends in Chico and hanging out at the parents pad in Oregon doing a little fishing and a little painting. I just started in on the Seabeck 4x4 00' 4x4 Ranger Extracab prerunner build today for a customer. Before it was sitting on 33's and a 3" bodylift, and soon it will have a Dixon Bros 4x4 LT kit, Fox Shox and bumps all around with custom bumpers, bedcage and fiberglass. If you'd like to watch the build look here:
http://www.explorerforum.com/forums/showthread.php?t=246504
The explorer is on hold for a bit while I build this ranger, but right after I'm done with that the explorer is going to get some more attention.
Josh S.
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Slight update, found a running 350 chevy today for $350. Gave the guy 100 to hang onto it until I go pull it on Wednesday
Can't wait to start getting sweet parts for it! The out to out meauserment on the headers is 26"; the inside of my framerails are 24"...I sense some major firewall chopping
- February 11, 2001
- Red Bluff, Ca
No lumber lumber rack??
- February 11, 2001
- Red Bluff, Ca
You're close enough to Canada to play hockey??
Updates!
Updates!
Josh S.
- January 19, 2001
- Seabeck, WA
- '93 sport 4x4
Tore apart the old motor...this thing is haggard!
Rogue wire harness clamp blocking the oil galley WTF?
Two-bolt main --- not what I was told
And so it begins.
And so it begins.
- February 11, 2001
- Red Bluff, Ca
Ahem.. 351. Cough.
- January 27, 2002
- Texarkana AR/TX
- 94 SAS sport
2 bolt blocks are good for 450-500hp. What are you planning on getting from this motor? Also, a machine shop can make your 2 bolt block a 4 bolt splayed main which is waaaay stronger than the stock 4 bolt block. All you need is conversion caps, ARP studs, and some machine work. I did one many moons ago and it was $400 or less, probably $500 these days.
Similar threads
- Replies
- 8
- Views
- 2,406
- Replies
- 11
- Views
- 2,217
