Thinking out loud about the IFS thing | Ford Explorer Forums
Turdle
DIY stunt double
Staff member
Moderator
Humboldt, KS
2000 Mounty
I took a real good look under a chevy blazer-full size-with a pro comp lift kit--
It looks like my Mounty-except bigger. The torsion bars are lengthened and the brackets moved back-
Why couldn't that be fabbed under an explorer? Control arms and all--
probably could..... but..... would need some manufacurer to build and test... and most aftermarket companies think explorers roll over enough on their own and dont wnat any liability
I think you are better off going with an RCD and ditching the torsion bars. The torsion bars cost a lot of ground clearance.
i agree with dan... all they do is bolt on a crossmember lower
Wait, so are you thinking about lifting your mountaineer? :)
For a serious off road 95-01 truck I would look into a full twin A-arm suspension with coil springs. Using an OEM application is an excellent plan, finding the best one and using it are the tough part. Good luck,
