throttle body spacer | Ford Explorer Forums
D rock
MN south st.paul
94 sport
were can i get a trottle body spacer for an 94 ex are their any ranger ones that fit or is thier none please let me know thanks
My question would be is it actually worth putting on?
Or would it be wiser to spend the money on a larger TB?
Ditto
Great for carbs, zilch for EFI
[hijak/] and buy the way how do those cherrybombs sound 91ex? I thought they might be a little raspy with the strait through setup.[\hijak]
I thought about adding one but after searching on here I became convinced that they are 99% worthless.
Like the guys above said, go with the larger throttle body. It is a much more realistic mod than a spacer gymic.
I agree...a TB spacer in the 4.0 is worthless.
On the larger TB topic...
Does anyone have a modified TB for a 4.0? If so, what size bore, manufacturer, quality, cost?
BBK makes some I think there 70mm or maybe 66mm I'm not sure but other people have modified there own by cutting down the center shaft but you'll have to do a search for that one.
My muffler is not the glasspack it looks similar to a flowmaster and its really deep and not raspy at all like I thought it would be, I've had a flowmaster and a magnaflow but this one takes the cake, I also mounted it as far back as possible so it wouldnt be too loud in the cab.
summit has the bbk for cheapest I think its like 212$ just put in your vehicle and go to air/fuel delivery section.
Thanksfor the TB info 91exploreron37.
What brand is your muffler? Can you post a video on You Tube or here of what your muffler sounds like? You Tube has some video clips of Explorers (4.0) with different types of mufflers. I personally like the super 40 sound on the 4.0 X.
I read the throttle body thing but would that really make any difference? He just cut out a piece of shaft right?
