tha704mafia
- May 3, 2006
- MOORESVILLE, North Carolina
- 99 XLT
Well I guess its time I did my sas since I destroyed my ifs unit. I am going to get the axle friday so the past couple of days i have been doing i little reading on here and have decided to put a parts list together and start spending money. My axle is out of a 1978 ford f250 it is sprung over with disc brakes the only down side it has 8lugs. So i figured i'd post my parts list on here and get some feed back on parts and stuff from some people with exprience before i go wasting time and money on something i might not need so here goes.
78 f250 hp44 $300.00
-Ruff Stuff Specialties
Ubolt plates and weld on shock mounts $68.00
Shock Towers $100.00
full size ford shackle flip kit $185.00 (saw it and not to sure about it looks like it would be easier than the outrigger with the shackle mount cause its all one peice) maybe not
full size spring hangers $33.00
- Local Metal shop
2x6 sqaure tubing .250 thick for the front cross member $50.00
Tubing for square front driveshaft??
-East Coast Gear Supply
Hi steer kit comes with Flat top knuckles with no arms ball joints installed, hi steer arms with hardware and heavy duty tie rod and drag link with 1-ton outters. $965.00
-Advance Auto Parts
1st gen steering box $142.00 (I dont know if i should use a drop pitman arm or standard???)
random parts i will need hubs brakes etc. $300.00
-4 Wheel Parts
Superlift springs 3inch lift $450.00 (or maybe stock dont know about that yet either)
-Randys Ring and Pinion
Yukon master overhaul kit $170.00
Yukon reverse cut gears 4.88 $204.00
Wheels and tires not decided yet because i need to find the kit to switch the 8 lug down to 5 or 6 something besides 8
Thats a total of $2966.00 without the wheels and tires, pitman arm, and the metal and ujoints for the square drive shaft. o yeah and shipping and tax ha
Thanks for reading
- Local Metal shop
-Advance Auto Parts
-4 Wheel Parts
Thanks for reading
