SaltCoveredFord
- January 15, 2010
- Northern VA
- '99 Eddie Bauer
I got my truck from my wife a few years ago - she had bought it new in 98 when we were dating. In the last two years, it just seems to be issue after issue with the truck. I know some have possibly been caused/worsened by my lack of superb maintenance that alot of you seem to be good at.
Today I went in to get emissions done. The guy couldn't even do the test because of an exhaust leak. He said it's the muffler that is leaking and a part of one of the inlet pipes going into the muffler. $500 he quoted me ($110 labor, rest muffler/pipe/fittings).
So I came straight here, looking for parts - was going through link after link of gibson catbacks when I stopped to think of all of the issues the explorer has and things that need to be done.
I made a quick list of issues off the top of my head. Some of the estimates are based on a repair iphone app that I've been told gives a pretty accurate range. I'm including labor costs for these. As handy as I like to believe I am, I know I'm not capable of much more than an Intake install:
There's also other things that I haven't listed that would be nice not to deal with: having to disconnect the CD changer because it too was draining the battery when the car was off, lack of a rear windshield wiper that actually does a decent job, having to use a cassette tape adapter to listen to Sirius, etc.
I'm just not sure I want to put that much money into a 12 year old truck with 120k miles on it that has seen better days. I'm sure I'll miss alot of things about her if I decide to move on. Just this morning I was snickering at other cars/vans and their crappy turning radius when trying to make a U-turn.
Not sure if I was looking for opinions or just to get it off my chest. This forum has been a great source of info and opinions - can't thank you all enough.
Forgive the interruption to your day.
-Salty
- Exhaust Leak - $500 (maybe cheaper, haven't looked into it yet)
- Ball Joints - $600-$1k I've put this off when it started showing up late last year and now it's to the point where the truck clunks occasionally when going over bumps. Likely upper and lower need to be done. No clue if sway bar or anything else may need replacing as well.
- Tires - $500-$600 One has a slow leak I've been dealing with, all 4 don't have much tread and need to be replaced to pass inspection next time.
- Electrical Drain - $??? God knows how many hours I've spent trying to track the source down. My temporary fix is to pull the fuse that seems to be the issue when the weather is cold (drain doesn't seem to be enough to be an issue in warmer weather). Downside being this fuse controls my speedometer, windshield wipers, power windows, power saver (turn headlights off dummy), etc. So whenever I get in the truck I have to plug it back in to use any of those features.
- Fuel Pump - $400-$600 Replacing the fuel filter and using BG products seemed to help a little, but in cold weather I still had to cycle the ignition a dozen times to build up enough pressure to start the truck. I'm worried because of all of the stories I hear about the fuel pump being replaced but it does not resolve the issue.
- Power Door Lock - $150-$200 Just started a week or so ago, drivers side door will sometimes not unlock when I push any of the unlock buttons. It tries, you hear the noise and all the other doors unlock, but sometimes the drivers door lock just does not pop up. Even when using keyless entry code the door makes a noise but does not unlock. Also, for some reason I now have to pull the lever to open my drivers door (from the inside) twice for it to open. I pull the first time and the door doesn't open, so I release and pull again. No clue if it's related or needs to be oiled, etc.
-Salty
