kolb
- October 29, 2007
- New Braunfels, Tx
- 2002 Eddie Bauer
Explorer has a timing chain rattle (4.0 sohc) and I got a good deal on a relatively low mileage replacement balance-shaft engine. I got to hear it run before it was pulled and it sounded good. So, instead of just dropping it in, I'm going to change out the guides and chains as a matter of precaution while the engine is out. I have already ordered the tool kit and now I'm about to order the complete timing set. I'll get the gears and all as I don't want to do the job again. I have been looking at the Cloyes set but wanted to be sure they were still the recommended set to buy. Also, other than normal gaskets, seals, and new water pump, is there anything anyone can think of that I should get as well while it's apart? Any modifications I should do while it's torn down?
