LStoudenmire
- December 29, 2001
- Charleston, SC
Well, it appears my front motor is broken. Window is stuck in down position. Switch appears to be ok,as I switched with another switch with same outcome.
The relay located behind the door panel close to courtesy light is clicking, and there is a clicking noise close to the window motor.
So I am assuming that it is the motor. Can anyone give me any info on how to remove it? I've removed a few bolts from the door around the window motor, but it doesn't appear to be budging.
