tire wear. | Ford Explorer Forums
tire wear.
justinf89
Hampton, VA
'97 xlt 4x4
Anybody know what type of wear this is? Its on both rear tires. 32psi rear 35 front. Pirelli scorpion at
Looks like its dry rotting/rotted between the tread
Yea I know the dry rotting sucks. It's passed two yearly inspections and I've driven to chicago and back 3 times so far(1700mi). I'm trying to figure out about the inch or so odd wear on the outer edge.
Slightly out of alignment. 2 likely reasons - torsion lifted front end, or worn ball joints
This is the back tires only, thats whats confusing
no ideas?
Have they been rotated front to back a few times?
The dry rot isn't helping either as the rubber is clearly getting hard.
That might also be adding to the uneven wear.
Is the other rear tire worn in the same spot?
I was under my truck today and noticed the outside edge was a little more worn on the passenger side and the inner edge was worn the same way... I am thnking I need to shim under the spring perches on both sides just a hair to align the rear diff...
Yours seems to have a bit of misalignment as well as dry rot tires...
