theluke19
- January 14, 2004
- Denver, Co
- 2005 Sport Trac
Well as some of you may know, I've been thinking of a good design for a self-built rear bumper/swingout carrier.
At this point, I'm considering building a 'Tiregate' instead of the rear bumper for a few reasons - specifically cost, ease, and design involved.
I don't know if this is a great Idea or not, only con's I've thought of so far are no more use of the Tailgate as a seat/worktop and the possibility of the sport trac plastic bed being too weak for this design (nothing a little metal can't fix..)
Anyhow, here's the design I went off of:
http://www.tiregate.com/vt_series_0.shtml
and here's my 'so-far's in google sketchup. Basically, there will be a square tubing frame that bolts in at various places on the bed, which has the latch/hinges on it. Then, there will be a 2" tube frame with the hub attached that will swing in and out. I still need to think of the best design for hinge and latch.
I would likely just put gussets to the left and right of the extension the hub is mounted on.
BTW - this is the first time ever messing in Sketchup-- the first 5 minutes is the hardest part, I tell you what!
