The upper intake bolts(upper or lower) should be around 10-14lbs.ft, but no more. Be careful with them, they will likely be too loose when you start. I'm not quoting a book, I just know the general torque specs which different bolt sizes can take. It's based mainly on bolt strength, and in the case of fragile intakes, the plastic or aluminum which can break. The 98-01 V8 intakes sometimes have one of the upper intake "ears" broken off.
Funny. Can you run a search through a member's past posts, for the word "Welcome"? The results could be funny.
Oh BTW, welcome to the forum.
