TexasBlack6
- June 5, 2003
- Augusta, GA
- 97 XLT
I need to use my 97 XLT 4.0 V6 to tow my Mazda MX-6 from GA to TX. The bumper tells me max tongue weight is 350 lbs and total max weight is 3500 lbs. My owner manual tells me the maximum Gross Combined Weight Rating is 4082lbs or 4535, depending on the gear ratio (which I don't know). And the Trailer Weight Range is 0 to 2086lbs or 0 to 2540lbs, depending on the gear ratio.
My MX6 weights:
Gross Vehicle Weight Rating = 3680 lbs
Front Gross Axle Weight Rating = 2160 lbs
Rear Gross Axle Weight Rating = 1545 lbs
(it's front wheel drive so it needs to face fwd)
I'll be travelling most of the way on I-10 which is fairly level.
What equipment do I need to get this job done? My bumper is equipped with the hole for the ball hitch.
What else do I need to know before I make this trip?
I know I'm supposed to turn the 4X4 to off. It's ok to use OD as long as it seems to stay in gear, right?
Thanks.
My MX6 weights:
Thanks.
