hdsanders
- November 22, 2004
- Atlanta, GA
- 2000 XLS 4.0L OHV
2000 Explorer XLS 4.0 OHV -Check Engine light was on and I took it to Autozone to be diagnosed. Code 122 was present so I replaced the TPS.
Check Engine light did not go off. I disconnected the battery and it cleared it for about 1 day. Took it back to Autozone and now it showed either P0121 or P1121.
Is there something I could have done wrong when replacing the TPS or a step which should have been taken that I may have missed? Haynes manual did not give a detailed explanation as to replacing, just said to make sure it was engaged. How do i know if it was engaged properly?
Thanks for any help!!
