SCMark
- March 28, 2009
- Anderson, SC
- 1997XLT
I want to know if this is normal. I am replacing my transfer case, and when I started sliding it back to clear the splined output shaft from the transmission, transmission fluid started pouring out. Is this normal? I was under the impression the transmission had a rear seal, and the rate of pour out was as if not seal was installed. Just want to know if it is normal.
I will get back under it after I get a truckload of cheap paper towels to soak it up so I am not crawling in it.
