- August 3, 2000
- NORTH IDAHO, 7B
- B2 "Slightly" Modified
- Callsign
- FOURTEN
Even without a transfer case bolted in the engine will still have the noise and the trans will still not shift
You can test the transfer case a little bit if you put the truck up on jackstands
Both cat converters completely plugged at the same time? Not likely!
Fix one thing at a time
We must rule things out!
How long is warranty in engine? As soon as lifter noise appeared you should be on phone w engine shop
