yoster
- August 6, 2010
- Clovis, CA
- '06 Eddie Bauer v8 4x4
Love you guys, but, I've seen everything on youtube, which is what started the questions
BUT - this is good for others to see..becase as you see at 8:36, it IS free-floating (see guys, this is why it's dangerous to assume or give others advice based on what you own, if what you own is different )
So I already know I need to drain the radiator fluid (or at the very least be ok with some leaking out during the swap). What the video doesn't answer though is if there's a secondary *internal* seal between that free-floating threaded fitting and the black plastic case. That's the basis of my question, and what everyone says can fall down and why they recommend doing it on new radiators with it flat on the ground (vs vertical). And (presumably?) why fordtechmakuloko recommends doing it when new/dry 'so there's no cross-contamination' (per his words)
Anywho, doesn't seem like I'll get a for-sure answer on this, so might just need to gamble and find out myself.
