Transmission Filter | Ford Explorer Forums
Transmission Filter
Giacomo Verdi
2000, Ford Explorer Sport
Hi! Today I removed the transmission filter and I found 2 codes on it....I have bought a filter on the web but seems to be too high. What is the good part number?
Now I believe the first number XL2P-7A098-AA it's lower (as the image near the code) and the XL2P-7A098-BA is higher, true?
https://www.facebook.com/groups/43274374114/?fref=ts#
Can you get a sidview picture of both filters? Is this for 2wd or 4x4?
Are you concerned about the depth of the mounting bolt hole? Did the filter bolt on the old filter have a spacer on it? Bolt length for filter is 55mm.
The longer snout is for the 4 wheel drive version, or if you have a 4 wheel drive oil pan installed on a rear wheel drive transmission.
