Transmission Fluid Flow Rate | Ford Explorer Forums
IZwack
Moderator Emeritus
Germantown, MD
1998 Ford Explorer
I may undertake a personal project this winter dealing with our transmissions during off road use.
Anyways, I need to get an idea of the rate at which the transmissoin is pumping fluid -- for example, at the lines that goes from the transmission to the transmission cooler.
So does anyone have a figure say during idle or at a certain RPM (gpm or lpm) ?
sorry to jack the thread, but how much tranny fluid should my 98 v8 explorer have?
I don't know if I'm on the right track here,
A friend with a 70 1/2 camaro ( I know) , had a power steering pump leak. Did some research and discoveres that some guys are running the ATF lines to the steering box, then cooler, and eliminating a power steering pump.
Isn't this harmful to the front pump?
sorry if this is hijacking?
Maybe, but its just a Chevy, so there is no great loss. :p ;)
Actually, I would wonder if the steering force might be kinda erratic with that setup. I don't know how constant the pressure is in the trans cooler lines.
dogfriend said:
In my factory manual, there is a transmission cooler flow test. To perform the test, you disconnect the cooler return line from the transmission and reroute it to fill a funnel in the fluid filler (dipstick) tube. According to this test, you should get a flow rate of 1 liter (1.05 qt) every 30 seconds.
There we have it - thanks! I'll assume this is at idle :D Thanks again!!
A friend with a 70 1/2 camaro ( I know) , had a power steering pump leak. Did some research and discoveres that some guys are running the ATF lines to the steering box, then cooler, and eliminating a power steering pump. Isn't this harmful to the front pump?
I guess that would work for emergency purposes but I don't think the transmission's pump provides enough pressure to fully support the requirements of the steering box.
Yeah, we sometimes do a flow check before we install a new transmission. We test out of the cooler to make sure it isn't stopped up
-Drew
Sonnax corp actually makes a flow tester called Sonnaflow, to check out adequacy of flow. Not sure if their test data is readuly available anywhere though.
Glacier,
I tried emailing, send you private messages. and calling you?
But I get no response. What do I owe you for postage?
James from Hawaii
jtsmith said:
about tree fitty
LOl this guy is always hacking -- dont pay attention to him :confused:
BTW thanks for hijacking MY thread!!! :D you hijackers
