The rear diff has a tsb that says replace with 75w140 synthetic. Trucks with a posi also need friction modifier.
If you just drop the pan and change the filter, you will only lose a few quarts. Motorcraft.com has the part number, or rock auto. Try amazon and ebay for the best price. There is no dipstick so you will need a fluid evacuator and an 1/8 inch pipe threaded nipple fitting to fill the pan back up. Use dexron v fluid. Depending on the mileage, only changing a few quarts is probably a good thing.
I drop a quart every 3k with the oil, only takes 10 minutes more and the shift quality is like new, and the oil red like new, if you skip and go to 6k, its starting to turn brownish.
I've been looking All over the place to figure out how to flush my 2005 Explorer and I thank you for this advice cuz it just makes perfect sense I got 13 qts mercon V got a new filter I got the pan down and old filter off. And Iknow that 12.7 quarts have not come. And I been trying to figure out how to get it all out.. How long should I run it? how many miles? Before I drop the trans pan again. So I should put in 4 quarts at a time?Yep, drop the pan and replace the filter. Refill, then drive it a bit. You can drain/refill the pan a few times and get most of the old fluid out that way without a flush.
The transmissions from DORF are JUNK!!!I don't plan on putting Lucas in my tranny unless it starts acting up, and I have nothing to lose. My truck is symptom free at 120k, which to me seems surprising, given the other posts here.
Pro's... how long do these 5R55s trannies usually last?
One thing I don't really like about my Explorer is the torque management for the tranny. The thing shifts like a wet noodle. There is an awful long, yet probably correct, pause between shifts when the vehicle is warm. Being an EFI tuner, I know this is in the calibration on the upshifts, when warm. I have SCT software for modifying this, yet I know better than to remove all torque management. On the GM 4L60E's, that is a real good way to wipe out a tranny, since the tranny can't hold up to the amount of torque the LS engines have. I don't know if that is as big of an issue on Fords, but either way if I modify the torque management in my tune, I won't remove it entirely.
Any pros got any experience with the effects of removing torque management vs longevity on Fords?
