Transmission line flow direction? | Ford Explorer Forums
Turdle
DIY stunt double
Staff member
Moderator
Humboldt, KS
2000 Mounty
I'm trying to install a second trans cooler and will be using an in line filter to couple the 2 together.
The 2 lines come to the rad support and are clearly separated. one is more to the driver side.
Could someone tell me please, which one is the return line? Thanks!
I think I found it
Yes, it just uses an oil filter. I found it easiest to come off the hard lines where they turn into hoses.
On mine the line on the drivers side was the pressure line, I went from there to the in side of the filter unit and from the filter back into the aux trans cooler.
take off both rubber lines then just have somebody start it (stand back, that fluid is like a rocket!) and as soon as it starts kill it.
thats how i did it...little redneck i know. maybe not the cleanest or best way but it does work!
