Solved Transmission servo piston shaft broke in the bore.
Shtiv
Bothell, WA
02 XLT
Hi guys,
To leave out a long story I was replacing servo bores, but had to remove the new ones because of a problem. So while trying to remove the piston broke its tip in the bore. I believe I have bought every tool imaginable to get the thing out. Due to the tight space and the exhaust in the way I cannot get my drill in to try and use screw extractors. Not sure why its so tight in there, but it is. Any ideas for extraction???? I then removed the pan, filter, and tried to remove solenoid pack, but the solenoid pack does not want to come free, seems to be stuck in the part where it attaches to some kind of bore? If I remove the solenoid pack could I access the broken tip?????Thanks for any help.
BrooklynBay
Moderator & long time member.
Staff member
Moderator
Brooklyn, NY
88 89 93 95 96 Aerostars
Shtiv
Bothell, WA
02 XLT
Thanks for your reply, thats one thing I have not thought of. I still have no way of grabbing a hold of it to extract.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Shtiv
Bothell, WA
02 XLT
That I have not, its a good idea but the problem is I do have any bored holed left down the center of the piston. I broke in the worst spot possible.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
Shtiv
Bothell, WA
02 XLT
I will give it a try, I have exhausted all other efforts without removing exhaust/tranny altogether. Any more ideas please share them. Also, any ideas why I wouldn't be able to wiggle the solenoid pack free and off? Also, I was just locking up and my puddle lights (which I just changed to LED) and the interior lights were not going off after I locked it?.
Thanks!!!
BrooklynBay
Staff member
Moderator
Brooklyn, NY
imp
Location
West-Central AZ along the Colorado River
59 Ranchero F250 D'Line
@Shtiv
Can you remove the valve body, consult appropriate diagrams to find the port which carries oil to the servo, apply air pressurte to that port, it might just push the piston out. imp
PS: If you cannot find info determining ports, post that. I can post images of which are for what.
BrooklynBay
Staff member
Moderator
Brooklyn, NY
I thought about suggesting compressed air, but he will need an air test plate, compressor, and a blow gun. Once the valve body & solenoid block are removed, the shaft should be easy to remove but there's a chance that the apply strut holding the band might come off. It might be better to leave the solenoid block & valve body alone since assembly will require a torque wrench, and new gaskets.
Some other thoughts that I had were to use a slap hammer with a stud gun, but where could you get a stud gun just for one job? There's limited access with the transmission in the vehicle, so there's no room to get a stud gun or a slap hammer in there. It might be possible to use a small slap hammer with a screw driven into the broken shaft.
Shtiv
Bothell, WA
02 XLT
I have the screws removed from solenoid pack, just cant get the solenoid pack out, it wont come free. Will get photos of the area of the solenoid pack that is catching in the morning. Wondering if anyone knows where I can find instructions on removing transmission? Thinking about picking one of these up and starting from scratch, http://www.ebay.com/itm/291705870463?item=291705870463&viewitem=&vxp=mtr. But feel like I would have to buy a lot of parts for this, and becoming expensive? Still hunting for more ideas on how to get current one working. Thanks for everything so far.
Shtiv
Bothell, WA
02 XLT
This is the part of the solenoid pack that seems stuck, everything this feels free. All screws are out, but this part is not working free?
transman304
Morgantown WV
2001 Honda Accord
Did you take out the bolt that holds in the connector on the outside of transmission?
Shtiv
Bothell, WA
02 XLT
Wasn't aware of bolt on outside of transmission, so probably not :). Could you possibly describe how or where to look for this bolt? Thanks
transman304
Morgantown WV
2001 Honda Accord
Where the connector on the outside plugs into solenoid pack there is a bolt with a 7 or 8 mm head dead center in the plug.
Shtiv
Bothell, WA
02 XLT
View attachment 95314 Where the connector on the outside plugs into solenoid pack there is a bolt with a 7 or 8 mm head dead center in the plug.
THANK YOU!!!!!!! it was the connector. Is there any good free manuals online of how to remove the transmission? I might just do an overhaul since Im in here. This forum is awesome, thanks for the help again.
Shtiv
Bothell, WA
02 XLT
So I got the solenoid pack off, was hoping I was going to see more, any ideas how to access the OD bore that has the piston stuck?
Shtiv
Bothell, WA
02 XLT
This is where I'm at currently, still searching for what I believe is the OD bore with the piston stuck.
L 2002 v8 XLT transmission servo bore issue Stock 2002 - 2005 Explorers 0
C servo bore transmission fix Stock 2002 - 2005 Explorers 8
B 5R55 Transmission servo bore re-sleeve, can it be done by removing the valve body? Stock 2002 - 2005 Explorers 3
D 2003 Explorer Transmission solenoid and overdrive servo Stock 2002 - 2005 Explorers 16
T Solved Air conditioning drain problem causing transmission shudder Stock 2002 - 2005 Explorers 2
I Engine or Transmission Swap? Stock 2002 - 2005 Explorers 7
J New transmission but getting code P0715 Stock 2002 - 2005 Explorers 0
T Transmission shifting problems? This may Stock 2002 - 2005 Explorers 0
A 2005 Explorer Transmission problem...imagine that.... Stock 2002 - 2005 Explorers 0
D Transmission swap Stock 2002 - 2005 Explorers 5
N 2002 does explorer xlt transmission help Stock 2002 - 2005 Explorers 0
J Transmission replacement Stock 2002 - 2005 Explorers 6
G Transmission Issues....of course! Lol Stock 2002 - 2005 Explorers 4
C Homemade transmission fill adapter. Stock 2002 - 2005 Explorers 1
K Explorer 2004 v8 4.6L, limited, transmission flush Stock 2002 - 2005 Explorers 4
T Unresponsive Transmission Stock 2002 - 2005 Explorers 7
M Mercury mountaineer transmission a Stock 2002 - 2005 Explorers 12
A Transmission question Stock 2002 - 2005 Explorers 2
B Transmission Pan Nut Stock 2002 - 2005 Explorers 1
M Transmission 2004 XLT 4x4 WTF? Stock 2002 - 2005 Explorers 2
H (At-home) Transmission fluid exchange Stock 2002 - 2005 Explorers 6
D Transmission issue? Stock 2002 - 2005 Explorers 8
D Transmission leak in front Stock 2002 - 2005 Explorers 4
S Will 2000 fit 2002 transmission explorer Stock 2002 - 2005 Explorers 1
J 0w20 in transmission? Stock 2002 - 2005 Explorers 9
M transmission wiring harness 2005 explorer xlt 4.0l 4x4 Stock 2002 - 2005 Explorers 0
J Transmission clunk(metal on metal) when when first shifting from 1st into 2nd gear Stock 2002 - 2005 Explorers 16
J Transmission swap Stock 2002 - 2005 Explorers 2
S Transmission issue Stock 2002 - 2005 Explorers 3
A Advice on Transmission, possible failure - 2003 Explorer 4.6 L V8 Stock 2002 - 2005 Explorers 12
S Transmission Help Stock 2002 - 2005 Explorers 2
G Transmission died Stock 2002 - 2005 Explorers 9
A 15w40 instead of transmission fluid? Stock 2002 - 2005 Explorers 13
J Transmission Stock 2002 - 2005 Explorers 1
M Dreaded Transmission Questions... Stock 2002 - 2005 Explorers 3
D RSC transmission option questions Stock 2002 - 2005 Explorers 1
M Transmission leaking with photos Stock 2002 - 2005 Explorers 12
Stvincnt Found this Transmission guy What's that catch Stock 2002 - 2005 Explorers 8
Stvincnt What are these yummy Transmission boogers 2004 xls Stock 2002 - 2005 Explorers 2
H Testing normal transmission behavior ? Stock 2002 - 2005 Explorers 7
H Transmission Stock 2002 - 2005 Explorers 2
T Solved Fuel pump power issues after transmission swap. Stock 2002 - 2005 Explorers 5
H SR55W transmission Stock 2002 - 2005 Explorers 2
L 5r55w transmission trouble Stock 2002 - 2005 Explorers 1
E explorer 2005 aut transmission Stock 2002 - 2005 Explorers 0
P Transmission 1st to 2nd harsh upshifting Stock 2002 - 2005 Explorers 1
S Harsh knocking noise from back of engine or front of transmission... Stock 2002 - 2005 Explorers 13
W swapping a 2004 explorer transmission in a 2003 Stock 2002 - 2005 Explorers 2
B Procedure for adding transmission fluid? Link or Advice? Stock 2002 - 2005 Explorers 10
I Transmission problems (kinda) Stock 2002 - 2005 Explorers 0
Similar threads
