Jeff213
- March 25, 2015
- Stockton, California
- 98 mounty 5.0 4x4
- Callsign
- KM6BVN
So I just got my headers that I welded up put on my 98 mounty, sealed up, no leaks from headers, then the transmission on my 4.0 manual started making a grinding noise when in every gear except 4th. I pulled the tailhousing and swapped the rear countershaft bearing, the noise quieted but did not go away, so I dropped the whole trans, and sure enough the input shaft bearing and front countershaft bearing are toast as well.
I loaded up the trans into my truck to go to junk yards to try to find a trans, and no joke, the torque converter started acting up in my 98 mounty. Truck stalls out when stopping unless you really feather the brake, then it will unlock the torque converter MOST of the time... (I have a spare trans for this one, if its more than just the solenoid i can just swap the trans).
Anyway, I was looking around at the wrecking yard for a tranny that would fit my 4.0, and there was a 4x4 manual that had a very shiny looking (freshly rebuilt?) tranny on it. There is absolutely no grime on the tranny but the engine and the transfer case have a ton of grime on them. It really looks like they put a rebuilt tranny on it rather recently.
I am now without a driveable truck, relying on my buick regal to get around. I am wondering, can I just go pull that 4x4 tranny, transfer case, and driveshaft, and throw them on my 4.0 to get it back in action? I will probably convert it to a 4x4 later on but I need a truck now and I think this could get me going again.
