Tenz85
- December 25, 2011
- BC
Hi. Nice to meet everyone. I just bought a 2006 Explorer Limited about 2 weeks ago. I've started to notice some minor issues and symptoms of a problem.
1. There's the slip in first gear with breaking - TSB related I believe. (No big problem).
2. Recently noticed the motor was shaking the whole car while at idle or at stop lights. Wasn't sure if this was a valve not firing properly because of fuel pressure, bad plugs, or just some water in the gas tank.
3. Then there's transmission slip shifting between 2nd and 3rd gears. I noticed it when I really hammer the throttle and get about 2500 rpms. It will hunt for the 3rd gear and if I easy up on the throttle it will stick in 2nd gear at a high rpm. (very common on the high way or up hills which causes me safety concerns)
4. Lastly, when in 4x4 if I hammer the throttle and get about 2500rpm the speedo tach drops about 10-20 and then it will buck. ( I think this is just the 4x4 slack between the front and rear wheels)
My main concern is the transmission slip between 2nd and 3rd. I think it's either a bad power band, all the cyclinders not firing because of some reason or another, or while accelerating the 4x4 kicks in because of a loss of traction so there is play between the front and rear wheels but I'm a little skeptical about the 4x4 issue because I can hear the transmission not shifting into 3rd gear right away.
All the help is very much appreciated.
